Results 1 to 5 of 5
Thread: Wiring Discovery!!! Amp or No Amp on Berlina VTII
    ScottB_33's Avatar
    ScottB_33 is offline Go Hard or Go Home
    VTII Berlina Supercharged
    Oct 2005
    Nowra
    Thumbs up Wiring Discovery!!! Amp or No Amp on Berlina VTII
    Was removing the rear parcel shelf on my VTII Berlina and discovered wiring harnesses not connected to anything, but were found to be near the rear parcel shelf speaker covers. On further investigation I discovered an unused connector down the LHR quater panel with same coloured wiring code as the two what looked like speaker wires. Does this wiring in 1/4 panel belong to the factory Eurovox Amplifier (Calais owners out there pls help.) Also the Calais head unit has provision for two connectors at the back, so can anyone fill me in on what this upper connector is for??? I thiught it was for the amp but now am not so sure if the wiring is already in place for the upgrade!!
    WH Statesman 5.7
    Jan 2006
    my wh has the same setup as the calais and behind the spare tyre the factory amp is bolted there which connects to the twin 8inch subs on the parcel shelf so i wouls yes thats what the wiring is for
    ScottB_33's Avatar
    Oct 2005
    Nowra
    Thumbs up Wiring Solved and Parts Purchased
    Have now spoken to a couple of wrecker friends who have calais vehicles in their yards and we have tracked down that the wiring is in place for the subs and amplifier, so I have purchased both and will be connecting them in to my car at the end of this week. So thanx guys for the help and any other Berlina owners out there i'm sure the wiring is installed in your vehicles as well behind the parcel shelf and the rear 1/4 panel in the boot!!!
    troyjm310's Avatar
    troyjm310 is offline Yortabulous
    VX Berlina series 2
    Oct 2004
    Wesside Sydney
    so thats in your VTii Berlina ...
    hmmm i have a vx ii Berlina and havent actually seen any of these as i have ripped the heck out of my car when installing the new sub amp and HU ?? hmmm
    ScottB_33's Avatar
    Oct 2005
    Nowra
    Thumbs up
    Well now I am confused!! Hooked the factory subs up to the rear parcel shelf wiring harness connectors, put the amplifier in its correct position and wired it up using the supplied connector taped back in the boot. Will not work!!! There must be another harness missing that connects in and then goes up to the radio. Pulled the car apart today to try and find the harness end!!! Noticed that fuse 24 for Subs and Amp only has one terminal which is power 12volts in. What does the other side of the fuse go to???? Do any wiring gurus know what is missing and where it should run too?? Any help gratefully accepted. I am running a factory calais maestro H/U
  1. Factory Amp wiring in VTII Berlina
    By ScottB_33 in forum Car Audio
    Last Post: 12-12-2006, 05:12 PM
  2. VTII Berlina Steering Wheel ?
    By nmldb in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2006, 04:02 PM
  3. MY VTII Berlina Supercharged
    By ScottB_33 in forum VT - VX - VU - WH - V2
    Last Post: 21-03-2006, 09:23 PM
  4. Fitment of Calais Foglights to VTII Berlina
    By ScottB_33 in forum Electrical Wiring / Questions
    Last Post: 03-03-2006, 05:33 PM
  5. MY 99 VTII S/Charged Berlina
    Last Post: 06-02-2006, 05:26 PM
