Results 1 to 12 of 12
Thread: CD Stuck
    VZCalZone's Avatar
    VZCalZone is offline now choppin the VZ
    vz calais, vx2 exec
    Sep 2005
    Default CD Stuck
    My head unit (Stock) has decided to completly ignore the fact it has a CD function. My CD wont, play, eject or anything. The CD button simply mutes the radio and I want my CD back. (sob) HELP I;m sinking!!! no really any idea how to fix it, it;s driving me nuts.
    That the automobile has practically reached the limit of its development is suggested by the fact that during the past year no improvements of a radical nature have been introduced.
    Scientific American, June 2, 1909.
    Drinking and driving: there are stupider things, but it's a very short list.
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    VY commodore acclaim
    Power Driver 2.0 Champion!
    Mar 2005
    This happened in my VY. Had to pull the CD player out and gentle move cogs etc to remove the CD and reset the mechanism to think no CD was loaded. After this, Worked like a charm..
    VZCalZone's Avatar
    vz calais, vx2 exec
    Sep 2005
    the second sounds better to me. A VY has a different head unit does it not? (mine has a Eurovox)
    VZCalZone's Avatar
    vz calais, vx2 exec
    Sep 2005
    Quote Originally Posted by Krustyone
    got the cd out but how do you reset the mechanism. The machine still thinks it's in there. Not that it done anything with it when it was.
    VX II Acclaim
    Oct 2005
    Sunshine, Vic
    This used to happen to me a fair bit in the last couple of months. I'd just keep pressing eject and with an old cd I don't listen to, slide it into the mouth and wriggle it a bit. Usually got it to eject.
    VE SS V Utility
    Aug 2005
    Darwin, NT
    Does your stock HU have a very tiny hole somewhere on it?
    Might be a reset button somewhere on it that'll re-flash the primary firmware on the HU back to it's factory default. Might work.
    Otherwise, it's time to install a new HU
    Just pull it out and crack it open to get your CD and buy an aftermarket HU.
    VZCalZone's Avatar
    vz calais, vx2 exec
    Sep 2005
    this will seem silly to you guys but i like having the stock HU. I'll have a look for that hole. thanks
    -Junior-'s Avatar
    -Junior- is offline <-- Back to Back in 2010
    vn auto
    Apr 2006
    S.W. Sydney
    If you do have a series 2 radio, pull the volume knob off. There is a reset button behind it.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    unfurtantly you are not looking for a software reset. Although it may work as it may cause the mchanism to reset themselves but if not you will have to re-open the unit and I would suggest getting a shop to look at it. Explain what happened and they cfan reset it in a matter of minutes.
    VZCalZone's Avatar
    vz calais, vx2 exec
    Sep 2005
    Smile
    hey guys, tonight I disconnected the battery, reconnected, entered the code, fired her up and walla. problem fixed. Naturally the hardware thought a CD was still in the drive but the software thought it was empty (it was, as i said previously I manually took it out) so i just pressed eject. Problem solvered. The moral of the story is try the simple things first, I went a month with no CD player because i thought the problem was too difficult when really it took five minutes to fix. Never did find that reset button by the way.
    VE SS V Utility
    Aug 2005
    Darwin, NT
    Essentially you've done the same thing as let's say pushing a reset button. Disconnecting the power has drained anything that can retain memory (even capacitors have a role) so you've lost all your radio station presets but at least the EEPROM / flash memory on the HU has gone into a reset cycle and is running the program from the start again resolving the CD stuck issue.
    Glad to hear everything is alright.
    It's true that it's always the most perplexing problems can be solved by the most simplistic solutions.
    Math's teacher... :b:
  1. Stuck CD
    By f1_power in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-10-2010, 10:44 PM
  2. im stuck what to do next?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-04-2007, 10:45 AM
  3. still stuck in the 70s help me
    By mutant in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-03-2006, 08:59 PM
  4. What Ya Got Stuck On Ya Car
    By soulyouth in forum The Pub
    Last Post: 04-08-2005, 09:21 AM
  5. Stuck?????
    By liquidforce_134 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-12-2004, 07:48 PM
