Results 1 to 7 of 7
Thread: Power cable causing static when listening to radio?
    VQ2STATO Guest
    Question Power cable causing static when listening to radio?
    I am getting static coming through my front speakers ( only
    when listening to radio, playing cd's crystal clear )
    This static is there even when engine is off.
    The front speakers are run straight from head unit ( no amp )
    I also have 2 12 inch subs powered by an amplifier,and if i dissconnect the
    amplifier power cable from the battery the radio reception is crystal clear?
    I have tried a different antenna, made sure antenna has a good ground,
    made sure power cable was not too close to speaker wires.
    I even tried a different head unit but i can't get rid of this static.
    Can anyone help me?
    bretttaylor.1 Guest
    The problem is because of your amp and i would suggest that you don,t have the earth on your amp correct or you have a fault with your amp, check install guide for you amp or test with a test lead from earth the the case of your amp.
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Quote Originally Posted by VQ2STATO
    Can anyone help me?
    rfi, radio freqency interference mate im guessin, try new speaker cables , a earth with crimped lug.
    Cheers.
    * RVN 355 *
    vrpower95 Guest
    it could also be that the wire behind the front speakers is touching the body of the car
    BOGANV8's Avatar
    BOGANV8 is offline I gotta V8 whoot whoot
    VX 02 SS LS1
    Dec 2005
    Armidale
    i not to sure but i have heard that if you run your power supply for the amp and speaker wires together they can create static
    Just a thought some please tell me im wrong bout this :b: :b: :b:
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Power wires and speaker wires won't effect each other. Power wires can effect RCA's if they are too close though, as RCA's are a low voltage and induced noise will be more evident.
    BOGANV8's Avatar
    VX 02 SS LS1
    Dec 2005
    Armidale
    Quote Originally Posted by StoneX
    Bugger thats what i meant to say but it came out wrong i even checked my post to and it ddint even click then...:b: :b: :b:
  1. VT amp power cable
    By danx in forum Car Audio
    Last Post: 15-07-2006, 05:21 PM
  2. Power cable causing static when listening to radio?
    By VQ2STATO in forum Electrical Wiring / Questions
    Last Post: 10-04-2006, 10:02 PM
  3. power cable
    By matrix in forum Car Audio
    Last Post: 28-03-2006, 10:35 PM
  4. Power Cable
    By Brycestro in forum Car Audio
    Last Post: 25-03-2006, 02:26 PM
  5. VN/VP Commodore Radio to Sony HU cable
    By Waussie in forum Parts And Other Items For Sale
    Last Post: 06-03-2006, 04:48 AM
