Results 1 to 12 of 12
Thread: Aerial up when CD playing.
    VX II Acclaim
    Oct 2005
    Sunshine, Vic
    Default Aerial up when CD playing.
    Ok, finished installing the headunit yesterday. All wired up and running fine. But the antenna comes up when there's a cd playing instead of only being up for the radio. Is there any way to stop this happening? I know it's not a major concern but I hate the look of the antenna being up.
    Is there a fuse I can remove that will just stop it from raising? That I can put back in when I want the radio on. I know it sounds like alot of screwing around for such a small 'problem' but, put my mind at rest?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You can put a switch in line with the wire that powers the antenna. Or you could remove a fuse if you could work out which fuse it is... as long as it doesn't kill anything else
    jack.mc's Avatar
    jack.mc is offline Nothing witty to say :(
    VN Vacationer
    May 2005
    Sydney, NSW
    or you could replace the aerial with a manual one, that you have to pull up? might be more convenient than the fuse...
    2008 VE SV6 Atomic Green w/ 20" Supersports
    Sep 2005
    Canberra ACT
    I had a switch put in when my headunit was installed. That would be the best idea
    VX II Acclaim
    Oct 2005
    Sunshine, Vic
    Eh I'm not pulling out the whole dash again (I screwed the HU in). I'll deal with it. Thanks.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    You may find you have connected the amp remote/trigger wire to the electric antenna trigger wire on the H/U, instead of the electric antenna trigger wire.
    The difference being that the amp trigger wire has power when the H/U is on at all times (which is what your describing), and the electric antenna trigger wire only has power when the radio is on.
    You should always test these things before you screw it all back in.
    jack.mc's Avatar
    VN Vacationer
    May 2005
    Sydney, NSW
    mines connected with adaptors, and it stays up all the time - maybe it depends on the HU as well?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Some brands don't have separate wires. They just have the remote/antenna as one wire.
    VX II Acclaim
    Oct 2005
    Sunshine, Vic
    Yep, was only the one wire there. I was hoping it acted like a relay when the radio was switched on. Believe me, I did test everything before putting back together. Just before I connected the battery back up I remembered I hadn't connected the earth yet. So yes, I remember the testing phase =P
    Black VZ SV6
    Dec 2005
    I have the same problem, i am going to put a switch in the line when i get around to it. I want to source the button that comes factory in some models next to the T/C button so i can rig it up to that... but i've been a bit lazy.
    Drive it
    Like ya stole it!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    If you know an electronics tech, they could actually add a relay to a tunner supply or turn on voltage and create a proper antenna wire that only works when the tuner is selected.
    wollow Guest
    This could be as simple as checking you HU settings.. I have a sony deck that does that after a reset (factory settings) all it is, is a auto tuning setting, or the emergancy broadcast setting (im guessing that ones for the states or something) that automatically detects radio station frequency changes (and emergency broadcasts, aparently cutting whatever is on and playing the broad cast if it receives one..). If either of those is on your antenna will be up all the time, turn it off, and it will only be up if on CD.
  1. a/c playing up, please help
    By rusty_ss_2233 in forum VR - VS
    Last Post: 09-05-2007, 09:51 PM
  2. Air con playing up
    By anotherstockvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-03-2006, 05:52 PM
  3. playing Around with my VT
    By limnuy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-11-2005, 08:19 AM
  4. Currently Playing
    By Troy711 in forum The Pub
    Last Post: 13-07-2005, 09:54 PM
  5. Car Playing Up Bad....
    By Azza- in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2004, 10:12 PM
