Hey guys
I have a VY S and was wondering if anyone has connected subs and amps to the stock head unit.
I was wondering how much control you would have and how easy it is to do.
I would have the front and rear speakers upgraded, 2 x 12" subs and 2 amps (1 running subs and 1 running the speakers)
Is this possible with the stock headunit?
Thanks
Check out Phreddy's "Low level Outputs" thread, it's around here somewhere. You need to modify the headunit slightly to 'feed-in' RCA cables. I think that's how he's done it anyway, don't quote me on that.
so it is possible? what sort of control do you have with the stock deck? and does it sound good?
You should really do a search.
But here are the links anyway-
Low level output
Blaupunkt low-level outputs? You betcha! :D
Aux inputs
... And now, Blaupunkt Aux Input! (VY/VZ)
I have these in front of me at the moment, just got to install them in to the headunit.
Can't what till I finish the install.
