Results 1 to 6 of 6
Thread: VN Boot rattling
    Jun 2005
    Default VN Boot rattling
    ive got a 12 inch sub in my boot and i cant stop the damn thing from shaking. it just sounds bad from the outside. the boot garnish and a few other parts just vibrate like crazy.
    what have other VN owners done to stop this with their subs?
    one thing ive noticed that makes the worst noise is the little black thing behind the spare wheel. anyone else noticed this?
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    You can try sticking down all the parts that are rattling. A bit of double sided tape under the unsecured side of the numberplate will help that part. Little dabs of hot glue may help in places but you don't want to use too much in case you need to get things apart one day.
    Another idea is to line the boot with bitumen based deadening material. This will also reduce the sound of your sub from outside the car, and possibly improve it from the inside.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    The ovbious bit is to make sure that all the nuts/bolts are done up really tight.
    After that, it's just a case of sound deadening, and padding, if you've got an old tyre tube somewhere a few strips of that can be used to pad stuff out and stop it rattling.
    Gravity is proof that nature keeps getting us down.
    VN Executive II
    Dec 2005
    Agreed, make sure all nutts are tight.
    Make sure your spare wheel and tire iron aren't sitting loose.
    Bubble wrap behind the number plate.
    Expanding foam in a can for boot garnish. Use spareingly cause it will expand and pop the garnish completely off if you're not careful.
    Sound deadening mat for boot interior.
    "I Dont Suffer From Insanity, I Enjoy Every Minute Of It !!"
    * MY OTHER LIFE *
    *** CLICK THIS ***
    HQ_Statesman Guest
    VY SS
    Aug 2004
    SE Victoria
    pull the boot vents out and put tube tube rubber under all the boot garnishes holes and then tell us whats rattling!!!
  1. rattling...
    By CRAIGO_VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-06-2006, 12:14 AM
  2. Rattling
    By spauldj308 in forum V6 Development And Modification
    Last Post: 04-12-2005, 07:07 AM
  3. rattling vk
    By bigazza in forum Car Audio
    Last Post: 11-11-2005, 12:03 PM
  4. rattling
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 09:02 PM
  5. VN Boot Rattling / Vibrating...
    By B-T-GiZzLe in forum Car Audio
    Last Post: 17-08-2005, 05:25 PM
