Results 1 to 6 of 6
Thread: Using stock 10 stacker
    VT BERLINA, TOYOTA HILUX, NISSAN NAVARA
    Sep 2005
    Default Using stock 10 stacker
    Hi all,
    just wondering if anyone would know whether it is possible to use the stock 10 stack with an aftermarket headunit, I have found the wiring diagram pinouts for the din connector for the stacker and in the process of identifying the pin outs on my hu. Question is will it work or not??
    Cheers,
    Steven M
    Sep 2005
    Quote Originally Posted by Steven M
    Hi all,
    Cheers,
    Steven M
    Nope. The 10 stack uses individual clock lines for Tx and Rx so it's essentially two synchronous serial ports. Other manufactures such as Alpine us the old M-Bus, AiNet and whatever they feel like.
    If you want to get technical, interested in reverse engineering the Commy bus??
    Anyone interested in this at all?
    bangers's Avatar
    bangers is offline <<<There's a good present
    EL FALCON XR6
    Aug 2005
    NSW
    Nope. you can't mix brands between stackers and HU's. to do so requires an FM modulator. you can't direct connect.
    jgupte is offline Jughead
    VX Executive/VN Project
    May 2006
    Ermington, NSW, 2115
    Hi. Can you post the wiring diagram pinouts for the din connector ? I am trying to find a cable between the stacker and the head unit (for a Eurovox Maestro) but can't locate one, so am thinking of making up my own.
    Also I am looking for one of these stackers. Does anyone have one ofr sale?
    Cheers,
    Julio
    Sep 2005
    Quote Originally Posted by jgupte
    Cheers,
    Julio
    You can't have looked to hard for the cable...$20 from the wreckers, why bother making one.
    Ducati851 Guest
    Cheers,
    Julio
    I Know where you can get a six stacker but not sure if they are the same but I would say so as it a HSV one.
    http://www.nvu.com.au/products_show.php?page=5&cat=2
    $220.00
    Good luck
    prerhaps you could tell me the pinouts for the din plug as i need that info as i have just bought one head and stacker but no loom! do you or anone else know if you can fit vs-vr steering control paddles to this maestro unt too??
  1. HELP!! rehooking a stock 10 stacker
    By lisalove in forum Car Audio
    Last Post: 18-11-2006, 10:04 AM
  2. VX - Cd Stacker
    By latcham_01 in forum General
    Last Post: 13-10-2006, 03:55 PM
  3. VT Stock Calais Stacker issue's.
    By amshaw in forum Car Audio
    Last Post: 05-04-2006, 07:19 PM
  4. how come stock 1.8 auto lancer beat stock vl
    By crazy for vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-07-2005, 08:47 AM
  5. VK Calais stock auto to stock 6 cylinder manual.
    By TheKnightTemplar in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-07-2005, 08:01 PM
