Results 1 to 11 of 11
Thread: System + Amp Help
    VR
    Dec 2005
    Default System + Amp Help
    Hi guys,
    I've got a vr commy running a Pioneer HU & stocker 6" speakers.
    Im planning on upgrading speakers by adding,
    # 2X12" MTX 400w subbies
    # Sony 6" 180w front doors
    # Sony 6" 180w rear parcel shelf
    # Sony 4" 120w front doors
    Im hoping to run the subs + 1 set of 6" off 1 amp.
    1. can this be done
    2. what amp would i need to do this
    3. if i cant do this and need 2 amps i would like to run both sets of 6" aswell
    4. again what amps would be needed
    bearing in mind trying to spend as little as possible.
    Cheers!
    VR
    Dec 2005
    aslo if i drop 1 12" sub and change the other to a 15" would this be easier as i would only need 1 amp.
    Any ideas and suggestions will be appreciated.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    If you're going to have a set of 6" in the front doors, why would you also have 4" in the front doors? Wouldn't a set of 6" 3-way co-axials be enough? Or a set of 6" splits?
    If you did that then it would be very easy to run the subs and a set of 6" off the amp, and the other set of 6" off the h/u.
    Gravity is proof that nature keeps getting us down.
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Quote Originally Posted by jas_969
    Hi guys,
    1. can this be done
    Cheers!
    Ok, To many speakers....
    4 is enough. I would run a pair of 6" with splits in my front doors and the 3way's (6") in the parcel shelf. The HU should be enough to do the powering if not get a D class 4X50 (4X100 if you HAVE to...id say no) and that will run all four of thoese...however im sure the HU can handle it if its good. The subs can be run off 1 good 2channel or 4channel bridged. You could use a 15" with a bridged 2 channel but i wouldn't bother as the bass from 2 12"s is better than one 15" IMHO.
    In summary:
    4 Speakers:
    -2 6" splits in front doors
    -2 6" 3ways in parcel shelf
    2 Subs:
    -2 12" in boot
    1 Amp:
    -1 100W 2 Channel Amp
    (Maybe a 4X50W for the speakers)
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    VR
    Dec 2005
    in that case would i be better off buying 2 amps 1 for subs and 1 for speakers?
    can u recommend any amps and wat would i be looking at in $$$$?
    May 2005
    .....SE Burbs
    yep, go to jaycar...they ave good amps. $200 each for 4X50's (Dclass)
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    VR
    Dec 2005
    VY SS
    Aug 2004
    SE Victoria
    give us the exact model numbers of the subs or a price eange for the sub/s and amp and we will find you something.
    VR
    Dec 2005
    i want to spend about 400 hundred on 2X12" subs and an amp and would be as happy as larry if i could run 6" sppeakers off the same amp. but i dont think this can be done????
    VY SS
    Aug 2004
    SE Victoria
    well there are a few problems with wanting 2 subs and amp for 400.
    remember cabling cost around 60-100. so thats 300 for 2 subs and an amp left. 150-200 for a crap amp that will have enough trouble powering 1 sub and wont be any good for 2. and then thats 50 ea for the subs left.
    i am not saying you cant get 2 subs and an amp with cable for 400 but it will not be very good at all. probably sub-boss quality. if you just are happy with 1 sub then you can get everything you need for 400 from jaycar. eg: 12 inch sub and a good amp with cabling.
    as for using the sub's amp for speakers it really isn't as great idea. the power a sub needs is a few times that of a speaker and so if you used a amp capable of driving subs would wont stuff your speakers and if you used a speaker's amp you would stuff your sub because of distorsion. 12voltking has written up a beginners guide to distorsion somewhere.
    i would be allowing for a 2 sub system about $1000 minimum! 200 per sub and 400-500 for an amp and then the rest for cable and deadening.
    Quote Originally Posted by azkwazere
    aZk.
    not trying to be an arse but the 4x50 aint any good for subs and its a class ab not d. you would be better off with the 2x150.
    VR
    Dec 2005
    k thanx for the help i will have to try and save up a little more then.
  1. vn lpg system in vr
    By stackner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2006, 11:50 AM
  2. system cut out
    By REVDUP in forum Car Audio
    Last Post: 05-03-2006, 12:07 PM
  3. Is my system ok??
    By MTX_15inX2 in forum Car Audio
    Last Post: 07-12-2005, 04:45 AM
  4. System set up????
    By Jarro_sparrow in forum Car Audio
    Last Post: 17-08-2005, 05:38 PM
  5. Vr System
    By PIMPIN in forum Car Audio
    Last Post: 29-01-2004, 06:23 PM
