Results 1 to 4 of 4
Thread: Vt Parcel Shelf Speaker Grills
    Apr 2005
    Default Vt Parcel Shelf Speaker Grills
    Hi
    I have a VT without rear speakers, i went to holden and purchased the factory speaker grills.
    The parcel shelf has an outline of where the grills fit but no holes or slots for them.
    Does anyone know how to fit the grills.
    Thanks Trev
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hiya Trev.
    Well, when I did mine - in both the ol' VT and in my VZ, I used a jigsaw (after I'd given it a VERY good clean-up and fitted a nice new blade) to cut around the opening but not along the line moulded in - if you do, the grille will fall straight through! Try to cut about 5-6mm inside that outline, then where the tabs on the steel grille are, just stitch-drill with about a 2.5mm bit to create a slot in the recessed outline. Poke the tab through there and fold it down nice and tight, plus I mixed up some epoxy glue and blobbed a bit of that around there as well to hold them nice and firm. Voila!
    Oh, maybe I should mention that I cut from the inside of the trim panel to minimise the "furry edge" left around the hole. Makes the jigsaw a little harder to stabilise though.
    Cheerz, hope it helps.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    grafxworld's Avatar
    grafxworld is offline KLRBASS
    VT GTR EXEC S1 - SOLD off
    Feb 2005
    one other note is to cut the carpet off inside the hole first, that way it won't catch a jigsaw and tear the lot off.
    take note of how you lay out the little tabs and take your time , its not too hard but can get stuffed up easy
    Phreddy's Avatar
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Quote Originally Posted by grafxworld
    Amen to that!
    (good suggestion about the carpet stuff too.... That was why I made the cut from inside, so that the blade would actually shear the carpet at the cut line, rather than trying to tear it off)
    Cheerz!
  1. VY SS rear parcel shelf speaker wires
    By ris00 in forum Car Audio
    Last Post: 15-09-2010, 09:09 PM
  2. 99 vt parcel shelf speaker wires
    By VT1988 in forum Car Audio
    Last Post: 21-11-2007, 02:40 PM
  3. WTD - VS etc Speaker Door Pod Speaker Grills
    By lil_oneblue in forum Swap / Wanted to Buy / Trade
    Last Post: 08-01-2007, 08:38 PM
  4. VX Rear parcel shelf 6X9 Speaker Electrical Question
    By Decksta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2006, 08:12 PM
  5. WTB: 6x9 speaker grills for VX parcel tray
    By grimavxs in forum Swap / Wanted to Buy / Trade
    Last Post: 24-03-2006, 12:29 PM
