hey guys, just got a 15" kicker c15 sub and i am wanting to hook it up to an alpine mrp-m350 amp.
is there anyway with these two pieces of equipment that i can run the sub at 2-ohms without stufing it completely??
sorry mate thats a bit much for me.... I would ask 12volt king, see if he replies....
Wire the two coils in parallel. That will give you a 2ohm load to present to the amp.
The only issue is that the speaker will be underpowered by a significant amount. This may well cause damage to the amplifier and speaker if pushed to ANY form of distortion level.
Wire it like this: (image "borrowed" from JL Audio tutorials section)
thank christ for the photo there Stone. I contemplated putting one up...but then I got distracted and never came back. Gotta love the daughter for that... "Daddy look at me!"
hi guys,
thanks for the replys. i should have been a little more precise but the boss was over my shoulder.
the 4ohm sub is single voice coil (2 connectors (1+ 1-)) will that make any impact.
i know a little bit about all facets of stereo systems - but this ohm business has got me stumped.
any help appreciated.
Jazack.
lol Jazack...the ohms business IS the facet of stereo systems. The sub decides how many ohms you are at. Not the amp. So, if it's a 4ohm sub then thats where you are at with it. From memory you are now rated well with the amp and sub matched nicely.
lol i meant i know a l'il about install.
sorry mate, i didn't understand what you meant.Originally Posted by 12Voltking
do you mean that they are evenly matched??
would i be better off with a dual voice coil 4 ohm sub running parallell or with a dual voice coil 2-ohm sub?
You would be better off with a dual voice coil sub with 4 ohm voice coils. When you wire this as shown above, it becomes a 2 ohm load for the amp.Originally Posted by Jazack
This explains series and parallel wiring: http://www.bcae1.com/srsparll.htm
thanx mate. i think im going to do this the smart way and go get a 2ohm dvc sub.
question: if i connect a 2ohm dvc in parallell will it bring the ohms down to 1ohm
Yep.
In series you add the resistances (impedences) together.
In parallel there is a formula, but if you have two of the same number in parallel it is just half. So dual two = 1. Dual 4 = 2, etc.
