Results 1 to 8 of 8
Thread: loose rca cables
    ben k's Avatar
    ben k is offline ben
    VP Calais S2
    Aug 2005
    radelaide...bay area
    Question loose rca cables
    searched but couldn't find anything
    my rca cables going into the back of my head unit are plugging in but obviously not right...was good for a while but is now sensitive to the slightest bump...they come loose and sub stops till the next slightest bump
    a mate of mine had a go at squeezing the ends of the rca cables with pliers so they might plug in better.,..but hasn't really made a difference
    anyone had this problem? anyone got an idea on how to keep them there on a permanent basis?
    thanks for any advice
    ben
    VP WAGON V6
    Mar 2006
    could always do the old trick you use with an extension leed.. tye it in a note if you knw what i mean, duct tape is what i used cause my splitters used to come out all the time.
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    Try some right angle connectors (http://www.dse.com.au/cgi-bin/dse.st...uct/View/P6632 )
    These usually have a tight fit and may help solve your problem.
    Otherwise use a bit of superglue or something similar.
    You could also try putting a dab of solder on the outside to hold them in.
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    i used to have a similar problem but it just fixed itself, plugs might have been dusty or somthing, now i have a new problem so i cant help ya out.
    ben k's Avatar
    VP Calais S2
    Aug 2005
    got dad (an electrical technician) to have a look at it today after trying several ideas....and it was the connection in the head unit the soldering had came loose...so he's soldered it back toegether and all good now
    craigvk's Avatar
    craigvk is offline Banned
    VK 5L Calais
    Jun 2005
    Quote Originally Posted by ben k
    Same problem my brother had. I had to resolder his RCA sockets on the head unit. Typical problem with space problems at the back of the HU.
    ben k's Avatar
    VP Calais S2
    Aug 2005
    i have got BUGGER all space back there...a couple of plugs with about 20 wires leading into them just sitting back there plugged into nothing...was going to cut them offbut bit shaky about open wires.
    craigvk's Avatar
    VK 5L Calais
    Jun 2005
    I thought the VK's were bad enough.
  1. Running amp cables???
    By sganro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-09-2006, 06:26 PM
  2. Problem with cables
    By asarrr in forum Car Audio
    Last Post: 15-04-2006, 02:22 PM
  3. diognostic cables for vt
    By CSL in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-03-2006, 11:38 PM
  4. Running Cables
    By Red_dwarf10 in forum Electrical Wiring / Questions
    Last Post: 03-02-2006, 07:30 AM
  5. New Cables
    By Pun in forum Car Audio
    Last Post: 04-04-2004, 08:31 PM
