How do you get to the front and rear speakers on a VT, do you just pop out the covers or does the whole door trim needs to come off?
The whole door trim needs to come off. Do a search, you should be able to find instructions on how to do it![]()
DONT POP anything out.Those so called covers are about $45 each.U will have to remove the door trimsOriginally Posted by GROWLZ
I did mine without removing the whole trim, just undone the screws along the bottom of the trim and used a right angled screwdriver, easy.
Thnaks guys 4 ya help
hey mate i did mine the other day infact, and i took the whole trim off and u may also need to cut the back of the plastic speaker mount off cause my speakers didnt fit. keep im mind when taking off the door lock pop up buttons use a small flat head screw driver and prise out the orange clip carefully.
