Results 1 to 8 of 8
Thread: help needed - amp not coming out of protection mode
    VP WAGON V6
    Mar 2006
    Default help needed - amp not coming out of protection mode
    basically my amp went into protection mode.. after aoutt 3 minutes of running a sub (fusion 1404 powerplant) my headunit was still going play music out the front splits like it should.. I turned the ignition off and then turned it back on.. Then my head unit poo poo itself an i fryed a track on it. I soldered it back up but still no go. Im not to worried abou that thou. I then moved back down to the amp.. With only the power earth and remote wire in it wont work.. its just sitting in protection mode; ive been using a direct 12v source for the trigger as the hu is sitting in piece of the bench. Any help would greatly be apprecitated
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    poo poo..... awsome havent heard that in a long time lol
    If the amp is not powering up then check fuses, should be some on the amp and an in line on the +cable
    also 12v through the trigger may be too much im not to sure.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    TT Supra/HZ Ute.
    Apr 2006
    Quote Originally Posted by semi
    12v too much for the trigger. itll be fine, dont worry about that
    ok, but the fuses would be my first port of call, failing that, check connections and test power going into amp. other than this i think it may be a pro's job.
    see if anyone else replies to this thread they have more ideas than me.
    good luck.
    VP WAGON V6
    Mar 2006
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    have you tried unplugging the speaker wires and trying to get the amp to turn on? thats if theres any visual sign that its on
    Black VZ SV6
    Dec 2005
    sounds like you might have fried the amps internal power supply. i did exactly the same to one of my amps a few years ago
    Drive it
    Like ya stole it!
    grafxworld's Avatar
    grafxworld is offline KLRBASS
    VT GTR EXEC S1 - SOLD off
    Feb 2005
    unplug the rca cables, and speaker wires , check for the protection mode power light , should be the power LED but it changes colour when in protection mode
    you should have 12v on remote wire
    12v on battery +
    and 12v showing when you use the ground wire and battery + using a volt meter of course
    your amp can shut down it it sees a floating ground thru the RCA cables or shorted tensel leads on subby or blow voice coil on speakers.
    another good one is having a screw go thru one of the rca cables under the carpet, it can blow the amp fuse or put in into protection mode.
    what brand of amp is it ?
  1. Vn 5Lt Diagnostic Mode How To Put The ECU Into This Mode
    By scotty1000 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-10-2005, 06:12 PM
  2. Car computer protection
    By bajdas in forum Electrical Wiring / Questions
    Last Post: 19-10-2005, 11:03 PM
  3. amp protection
    By muffman001 in forum Car Audio
    Last Post: 30-05-2005, 01:26 AM
  4. Protection mode on Amp....
    By Just_Ice in forum Car Audio
    Last Post: 26-09-2004, 11:00 PM
  5. Fuel Consumption Normal Mode / Power mode (Overdrive)
    By peeete in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-09-2004, 10:05 AM
