Results 1 to 12 of 12
Thread: What Fuse?
    holdensupporter2005's Avatar
    holdensupporter2005 is offline Donating Member
    VE SV6 Commodore - Silver
    Sep 2005
    N.E. Vic
    Default What Fuse?
    Hi everyone.
    I need to know what size fuse I need to use on my system
    I have 2 x 1000w Daytona subs which I am about to connect up to an 1800w amp. I have 4 gauge power wire connecting the amp to the battery. What size fuse will I need to have. I have been told around 150amp??? is this correct.
    Holdensupporter2005
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Technical - Fuses and power cable size
    http://www.bcae1.com/fuses.htm
    The main fuse is to protect the car/power wire if it shorts out, so it has to be rated lower than the cable. 4ga is rated to flow about 135A so a 150A fuse is way too big... The cable will get hot and possibly melt before the fuse blows.
    VY SS
    Aug 2004
    SE Victoria
    VYII SS UTE
    Feb 2006
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    The way I've always worked it was just add up the total current rating of the fuses in the amp(s) that I'm working with. Make sure that it's about 10A higher than that. That's what I normally go on.
    Gravity is proof that nature keeps getting us down.
    VY SS
    Aug 2004
    SE Victoria
    whats the RMS of the amp? nand the subs connected to it?if its really 1800Wrms then why in the world are you running 4GA???
    Sep 2005
    N.E. Vic
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    That amp has 50A worth of fuses. So a 60A fuse is all you would need on the main power cable unless you are running any other amps.
    The amp is actually 240Wrms, 1800W is just a bullshit number they've made up.
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Quote Originally Posted by StoneX
    Yeh, don't you love this "maximum" and "music power" or "PMPO" figures they quote for these amps??
    What a crock!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    Sep 2005
    N.E. Vic
    How do you work out the different wattages???
    (sorry for all the questions )
    VK
    Jul 2004
    Quote Originally Posted by Phreddy
    What a crock!
    how about advertising that it contains MOSFETs to sound cool? I guess it sounds better than just advertising that the amp contains transistors?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Quote Originally Posted by holdensupporter2005
    It says 4x60 in the link you posted
  1. Which fuse is which?
    By calais_304 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-12-2006, 03:13 PM
  2. What fuse does what?
    By Warooda in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-09-2005, 05:03 PM
  3. VX fuse
    By dcamo50 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2005, 07:14 AM
  4. Where is the fuse bos?
    By Shifty1 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 25-07-2005, 10:09 PM
  5. Fuse Box
    By Hgprem01 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-07-2005, 09:35 AM
