Results 1 to 4 of 4
Thread: new headunit in VX! (yet another threed)
    Jun 2005
    Default new headunit in VX! (yet another threed)
    hey all.. putting a new headunit in my vx.. just a question about the antenna up & down...
    how can i still make this work, if the only thing on my new headunit, is a single wire?
    thanks
    Apr 2006
    connect the aerial wire to the system remote wire on the deck. the aerial will go up wen ignition turned on, and down wen turned off.
    Jun 2005
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The stock head unit has a wire the same as the aftermarket, which turns the antenna on. So hooking just that wire up will make it go to whatever preset height you have it at. So before changing head units I made sure it was set to full height, so now when the aftermarket head unit turns on, it goes to full height. Hope that makes sense...
    Now, if you wish to adjust the height still, you'll need a switch with 3 positions. You would wire the centre position as nothing, wire the top position to the UP wire (WHITE WIRE) and wire the down position to the DOWN(LIGHT BLUE WIRE) wire. A spring loaded(so it reverts back to off by itself) rocker switch with a neutral centre position would work well. Just connect the centre pin of the switch to GROUND and connect the WHITE and LIGHT BLUE wires to either end of the switch. This should work, but if you don't understand, get a pro to do it
    See schematic of VT/VX radio system here.
LinkBacks (?)
  1. How Much For this Headunit
    By Infest in forum Car Audio
    Last Post: 22-10-2006, 04:25 PM
  2. VT headunit HELP!!
    By danx in forum Car Audio
    Last Post: 15-07-2006, 03:39 PM
  3. Old headunit versus New Headunit
    By SVZ_MY06 in forum Car Audio
    Last Post: 28-04-2006, 11:12 AM
  4. VZ headunit
    By Jordo1 in forum Car Audio
    Last Post: 24-01-2006, 12:02 PM
  5. headunit in VK
    By Shifty1 in forum Car Audio
    Last Post: 01-07-2005, 03:36 PM
