Results 1 to 10 of 10
Thread: Amp wiring query
    Vp Executive Wagon
    May 2006
    Sydney, Northern Beaches
    Default Amp wiring query
    hey guys.. i got a new car and ripped out the amp and sub from my oldy. i couldnt be bothered pulling all the wires through so without thinking i just cut it all off and pulled it straight out. ive still got the amp and sub but i need to know whether a normal wiring kit will do the job? or if i need the wires which come with the amp when u buy it???
    Any help will do, cheers
    VS Acclaim S2
    Nov 2005
    hey dude how's it going? Ok, a few things to consider. You could probably just go for a single amp wiring kit, just make sure you get one of an appropriate "gauge" power. Can you give us an idea of what wrms total you are planning on running from your said amp and sub?
    Sometimes you can save yourself a bit of money by buying all the cabling seperate and it might also give you some more options in choice. You'll need:
    RCA cables to run from headunit to amplifier, a remote cable (thin, i believe 16AWG is a good size) to run from headunit to amplifier, a power cable to run from your battery to your amp (once again, this is where we'll need to know how much power your running before we can say what size would be best. also should be at least 6 metres for a commodore sedan as a general rule of thumb), a ground cable (of equal size or bigger than your power cable. this should be as short as possible, most amp wiring kits provide 1 metre ground cable. this will need to be grounded to a solid metal part of the car) and speaker cables to go from your amplifier to your speakers.
    so here's cabling you'll need:
    power cable
    ground cable
    remote cable
    RCA's
    speaker cable
    By the way, very few amplifiers will come with wiring. You generally get the amplifier and the amplifier only.
    Cheers and best of luck
    Vp Executive Wagon
    May 2006
    thanks mate, yeh im pretty sure on the wiring kit i need. im running an 800w sub off a 300watt amp (850wat 'max power').
    its just that the amp came with a few wires including the remote wire... which is deceased. will the amp still run normally without the remote? or should i create a ground from the remote terminall?
    thanks mate
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    the remote tells the amp to "turn on" and wont function without it. run a remote wire from the remote wire on the head unit to the remote terninal on the amp.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    VS Acclaim S2
    Nov 2005
    what azzfox said, the remote wire runs from the headunit to the amplifier. when the headunit is turned on that sends a signal to the amp telling it to turn on. Some headunits may not have a "remote" wire - in this case you can connect it to the accessories wire, your amp will just turn on whenever you have your car accessories on instead of whenever you have your headunit on. if your looking for help on the right wire size, just look here: http://www.the12volt.com/info/recwirsz.asp
    cheers.
    Vp Executive Wagon
    May 2006
    thanks... i was getting confused with the 'remote subwoofer control' and the remote cable lol...where about is the accessories wire? im gettin the h'unit today.. a pioneer mp3 discounted from $350 to $130 at JB hi-fi.. fkn bargain!!
    Thanks for ur help
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Default Accessory wire location
    Quote Originally Posted by james_and_ his_VS
    Thanks for ur help
    Hey James, your new unit will have a blue/white wire with a female spade connector on it, the wire is labelled (System Remote Control (the shortest one in the loom). If you need the accessories wire then just let me know.....hope this helps cheers.....
    Lets work as a TEAM and do it MY WAY!!
    Vp Executive Wagon
    May 2006
    hey i just tried connecting the new unit.. i connected all of the wires and the stereo didnt respond to anything! the blue/white one wasnt connected to anything.. could this be my problem? its a pioneer DEH - 2750mp. thanks mate
    vp calais
    May 2006
    adelaide
    ok james here are the wires for your hedunit
    red - accessories 12v+ will only have 12v power when ignition is on
    yellow - constant power 12v+ will have constant 12v power even when ignition is off
    black - ground or earth connect straight to bare metal make it as short as possible
    blue - power antena unless u have a power antena useless
    blue/white - connect it to your amp (straight to your remote terminal on the amp)
    white/black x2 - left front speaker
    grey/black x2 - right front speaker
    green/black x2 - left rear speaker
    purple/black x2 - right rear speaker
    some units have an orange wire or such witch the illumination wire connect it to the same wire as you connect the accessories wire to
    Vp Executive Wagon
    May 2006
    thanks guys. i got it workin yesterday. thanks for all the help : )
  1. Centre Bearing Bracket Query & Tailshaft Ends Query
    By Sojourner353 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-12-2010, 07:48 PM
  2. CAI query
    By MJR_VR in forum General
    Last Post: 04-04-2007, 04:26 PM
  3. VT Query
    By raZel in forum Car Audio
    Last Post: 02-05-2006, 07:52 PM
  4. !!Query!!
    By vpkingdragger in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 02:42 PM
  5. Query
    By breast69au in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-04-2005, 10:13 AM
