Results 1 to 9 of 9
Thread: sub problems - was thumpin hard, now thumpin soft
    VX Executive S2
    Dec 2005
    Unhappy sub problems - was thumpin hard, now thumpin soft
    i think i've blown my sub or amp people!! heres a quick run down on what happened..
    i installed everything, head deck, amp wiring, amp sub and 6 inch components in the front one sunday. towards the end of the day (night) i finally got around to putting the sub and amp in which i figured was as simple as hookin up the wires and your off. i didnt get around to mounting it as i was tired as and wanted to go to bed. anyway i hooked it up, ground first as usual and the thing was thumpin. i was really happy with it, i decided i'll mount it the next day. i didnt drive to work the next day, i got picked up so the amp didnt get thrown around or anything it just sat in the car in my driveway.
    when i got home i went to mount the amp, i tested it first it still sounded great, so i unplugged the amp and sub, first mounted the sub to the backwall then mounted the amp on top of it (i know its not good for the amp but its a cheap amp so i dont care, plus it looks good) i believe at this stage i was rushing a bit. anyway i had everything mounted, hooked it all up to test and there was no bass!!! well there was, i could hear the subwoofer making noise but there is definatly something wrong, i checked all my connections, ground was on a nice sanded spot under my parcel shelf, 12v not near any other cables running up to the boot, every termination is nice and clean and clearly has a good connection. i cant seem to figure out whats causing this, it still makes bass but not alot of it, the protection light on the amp is not on and the fuse is fine. i really am stumped, i have a feeling its one of my connections somewhere as it sounds like its just not getting enough power. maybe something behind the head deck? i dont know i checked them all and they seem fine, any help will be MUCH appreciated, thanks!!
    Dec 2005
    Check the gains and filters on your amp, maybe you chanegd them by accident. Having these set incorrectly will cause the problems you described.
    VY SS
    Aug 2004
    SE Victoria
    VX Executive S2
    Dec 2005
    theres only 2 adjustments knobs per channel on the amp, ones in dB the others in khz, i played aroudn with them to no avail i'll try and swap phasing now
    VX Executive S2
    Dec 2005
    i checked the phasing, its ok i was hoping it'd be wrong, i tried swapping anyway to no avail
    benno_ is offline VT - ESSSSS PACK
    BLACK VT - S PACK, 5 SPEED
    Apr 2006
    sydney
    maybe cracked the sub box caz that happend to me and i split the sub box
    Did u drill the amp on if so u might of done that!!!!
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    VP WAGON V6
    Mar 2006
    ok i would say that you have either plugged your rcas around the wrong way or you havent plugged them in correctly. The other thing that it could possibly be is the wiring from the sub to the amp... Just double check it. I dont think it would be a cracked sub box cause that wouldnt cause it to loose ALOT of bass. That would simply make the bass sound bad and make weird noises etc etc etc
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Quote Originally Posted by ilovemyvx
    Hey there VX, Did u check your LPF(Low Pass Filter) switch and make sure thats on? u may have accidentally switched the filter to HPF (High Pass Filter) which would make your sub sound non existent.....What brand of amp is it? Let me know if this helps...cheers
    Lets work as a TEAM and do it MY WAY!! [/QUOTE]
  1. 'Soft drink can' rolling noise...???
    By Christina in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-03-2007, 06:47 PM
  2. Leather SOFT AS a BABY'S B@M
    By Car Audio Factory Outlet in forum General
    Last Post: 14-12-2006, 02:26 PM
  3. HOLDEN UTE Soft Tonneau Cover
    By timkeeley in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-11-2005, 12:09 PM
  4. looking is hard
    By zegerman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-11-2005, 04:02 PM
  5. Headlights problems, Hard Starting, Cruise Cntrl
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-08-2004, 07:12 PM
