Results 1 to 5 of 5
Thread: bad noise
    Jul 2005
    Default bad noise
    the other day i turned on my car and i was getting a bad whining noise from the stereo in the background, i can still here the music just fine. the sound wasen't there when i last turned the car on which was only like half hour before. i can hear it on both cd and radio but the thing is when i put my foot down the whine gets more high pitched. when i really turn up the stereo it downs out the whine which leads me to think that its a car problem not the stereo, like something thats blocking engine noise is playing up. so should i take it to my mechanic or the guy that installed my stereo? any ideas?
    foxtrot uniform charlie kilo
    vt belina
    Feb 2006
    sounds like it could be a bad earth from the amp,i would take it back 2 where you got the stereo done and tell them you want it fixed
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What equipment are you using?
    If someone else installed it, take it back and get them to fix it.
    vp calais
    May 2006
    adelaide
    i had this exact same problem with my vh. ive put in 100 os stereos and ive never had this problem but the stereo i put in my car does it. i was so pissed but i took the time to look at it due to the car being off the road atm.
    ok then its only the amp if its coming from the speakers that are hooked up to it. if you only have subs hooked up to it and the noise is coming through your speakers its not the amp earth.
    test your rca's if there loose in the back of the head unit thats can be a cause.
    try re earthing the head unit to a new point so its clean the wire is as short as possible and there is nothing else earthed to it.
    check the antenna earth.
    check the power wires for the unit arnt running to close to the engine.
    and if all of that fails then u have a real problem.
    but your best bet is then to buy a noise supressor.
    i hope this helpped a lil
    Jul 2005
    Default problem solved
    sorry about not replying back for few days my nets been down.
    i ended up spending about 15 mins just checking all the wires and connections best i could with out pulling the car apart. it ended up being one of the rcas had become loose at the amp, problay should have checked this before posting a thread but you get that.
    thanks for the help and advice.
  1. New Noise ... HELP
    By Ratty in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-07-2008, 09:59 AM
  2. Odd Noise
    By slipstream001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2007, 02:19 PM
  3. Sub noise
    By Brasso in forum Car Audio
    Last Post: 28-09-2005, 12:54 AM
  4. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
  5. Gen III V8 Noise.
    By Jaime S. in forum General
    Last Post: 10-01-2004, 01:24 AM
