Good afternoon all,
I am thinking about buying x 2 small speakers for my vr execs front door.
The stock ones in at the moment are shithouse.
With installing new speakers in the front do I have to remove all doors trims?
Or do I just remove the current stock plastic covers over the origional speakers?
Any help would be much appreciated.
Cheers guys.
Originally Posted by MJR_VR
Hey there MJR_VR, You will need to remove the door trims, The factory speakers are 6" If you have never removed one before u may find it quite a challenge....I think someone may have addressed this before, just do a search and see how u go....if u have no luck then i will try to help u as much as i can....cheers
Lets work as a TEAM and do it MY WAY!!![]()
I found 1 though it was for a VT I googled it and got a few things, cheers dude.Originally Posted by VQXTC
in the how to section theres a good guide to door trim removal, the window winder is probably the biggest hurdle so i've added some tips for that
-edit-
Removing Front Door Trim on VN - VS <-- door trim removal guide
attn Über geeks, i play Second life. Patrio Graysmark.
but your post was at 1145am? thats morning...Originally Posted by MJR_VR
yes get a fork, and bend the prongs so only 1 is sticking out, makes removing the winder handle easy peasy.
