Results 1 to 7 of 7
Thread: should i attack JBL???
    94 VR Exec
    Jul 2005
    Wagga
    Default should i attack JBL???
    i posted questions regarding wire sizing as i read this in the manual provided with the amp (JBL GTO 755.6 Series 2)
    the common respose, as it is well documented in other places about the safe current carrying capacity of certain gauge wires.... and yet, here is JBL saying in their manual, its ok to use 8AWG wire, with an amp that @ max draws 87A.
    AND..
    it has no recommendation for fuse size from battery to amp. I just expected more from such a well respected brand.
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Using a run of 7 to 10 feet I guess it would be possible to do that. but personally I wouldn't use that as a guide. Most manufacturers guides to cable sizes that I've come across tend to be on the small side.
    Gravity is proof that nature keeps getting us down.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    87A is the maximum current draw from the amp which would only happen if you played a sine wave just on clipping. Music would be lucky to cause half of that current draw unless playing constant bass (like d'n'b). It's just safer to go larger wire as people are stupid.
    94 VR Exec
    Jul 2005
    Wagga
    ok.. will do!
    not quite to the extent of 0AWG, but yeh, 4 will do!
    i'll throw in an 80amp fuse then.... i wont be running it @ max... cheers StoneX, sorry if i seem to be "attacking" you in other replies, i just seem to understnd some things differently. But i do appreciate the feedback and information supplied.
    VS CALAIS's Avatar
    VS CALAIS is offline S/C CALAIS
    VS S/C Calais
    Jun 2005
    MELBOURNE
    Ozzietj
    Im running the GTO 75.4ii and the GTO 601.1 on 4 gauge from battery to cap then 4 gauge again to amps , been over a year now no problems at all , apart from that you will be suprised at the JBL amps as i wouldnt change them for any brand ( thats my opinion ) love em
    SUPERCHARGED V6 VS CALAIS
    R.I.P Peter Brock 05 The Man The Legend
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    Others may think different, IMHO... if u got a high drawing unit such as an amp or inverter... go larger in cable gauge, obviously within some reason tho... maybe overkill of 10-20 amps (larger cable) of factory say-so with a fuse as low as u can go (without blowing) will protect ya gear pretty well
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by ozzietj
    AND..
    doesnt it say a 7-10' run? and would the fuse value be a bit higher than the max current draw?
  1. My VS Commodore Plan of attack
    By cizocizo in forum V6 Development And Modification
    Last Post: 28-07-2005, 03:07 PM
  2. Dash spac attack
    By wazzad in forum Electrical Wiring / Questions
    Last Post: 15-07-2005, 12:11 AM
  3. Server Problems - Under Attack
    By Darren in forum Site Feedback / Site Problems
    Last Post: 31-12-2004, 05:37 AM
  4. 9/11 Pentagon Attack
    By Troy711 in forum The Pub
    Last Post: 29-08-2004, 03:51 PM
