Results 1 to 11 of 11
Thread: Replace stock speakers in VZ
    HSV VZ GTO
    May 2006
    Gold Coast
    Default Replace stock speakers in VZ
    Sorry if this has been posted before, but I would like to replace all the stcok speakers in my VZ GTO.
    Has anyone done this before, and or is it the same as in the sedans? If so, is removing the door trim necessary?
    It does not look or sound like there are splits in the front, but I may be mistaken.
    Any help in the right direction would be appreciaed.
    Thanks.
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    Gday, as far as the woofers in the doors are concerned theyre pretty straight forward of removing the trims to access the speakers and pods simply via removing a series of phillips head screws followed by the door handles and locking buttons, with the woofers be sure to note polarity before ya disconnect as u will need to know what is what when u connect ya new speakers up. in a sedan setup easy way to go is 6-6.5in coaxials for rear doors, for front run a 6-6.5in split setup, i have JL 6in splits and work a treat, but may i add there is a bit of work involved and should i say a great deal of work if u chose to replace wiring. the woofers are easy, tho u will find the tweeters a bit of a task so heres a writeup how jus to get in that area.
    VZ audio
    now as for the parcel shelf if you have speakers to replace in this area you'll have to either look around on the forum or nicely ask for someone on the forum whos had experiance with those installs
    VZ SV8
    Aug 2005
    Default Door speakers
    I have found that on the sedans the front door speakers can be changed without removing the door trim completely. If you remove the screws along the bottom of the door, 5 or 6 in total facing up and in toward the metal door frame, then unclip the front and back edge of the door. This provides enough space to get a phillips no2 stubby screwdriver in to remove the baskets.
    It's better to remove the baskets, fit the new speakers and then replace the baskets with speakers in place. If you use 6.5 inch woofers the baskets will need to be butchered, a Dremel and a hot glue gun are your best friends here.
    Remember that water can find its way into the door cavity so retaining the back of the basket will maintain its water deflecting role.
    As for the tweeters, one screw per side and then lift up and back, they just clip out. The screw is on the outside behind the side air box duct covers.
    Hope this helps, Steve
    HSV VZ GTO
    May 2006
    Gold Coast
    Thanks guys.
    Will give this a go on the weekend.
    I think I will retain original wiring as I have read on other posts that it is quite diificult to change.
    Thanks once again.
    Phreddy's Avatar
    Phreddy is online now Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Ummmmm - just be aware myhsv - I think your speakers will be 2 ohm in the GTO. If you just replace them with 4 ohm speakers, the output power will be halved......
    What speakers are you planning to install?
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    hrm i was unaware of this phreddy, what other differences are in these systems?
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by Phreddy
    why ywould they use 2 ohm over 4? i know the obvious reasons, just wondering. also what sort of system is in the stock GTO? amps specs?
    HSV VZ GTO
    May 2006
    Gold Coast
    Now I am really confused!
    I assumed, which I know is dangerous at times, that the Blaupunkt set up in the GTO would be exactly the same as in the sedan.
    The only difference I thought was that there is a single speaker in each rear side panels> I assume that the sedan has a split system in the rear doors, maybe not. It looks like there are coaxials in the parcel shelf, have not tried to pull apart yet, as I was going to tackle front doors first.
    As far as 2 ohm is concerned, have never seen 2 ohm used in a car before!
    Appreciate your time in giving feedback Phreddy
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    ok what i suggest... have a look at the headunit... is it just the standard 6 disk (4ohm) or does it have a large centre knob on it with "premium" written onto the bottom of the headunit under the buttons? still questionable... dismantle door trim and pull out woofers have a look at the impedence or yeah see either holden service or a fully qualified car audio fitter.
    HSV VZ GTO
    May 2006
    Gold Coast
    Thanks for that.
    No ,it does not have premium on it, thus as you say, they must be the 4 ohms which is great!
    I have a set of Boston splits with crossovers.. Do you know of I can use the existing wiring and gust to via the crossovers?
    Thanks
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    yeah should be straight forward just trace back the wires ya required in the loom, from vauge memory should be a light pink and a grey wire for the left hand front door and a dark green and light green wire for the right hand door, check ya polarity before ya start disconnecting and cut wires. for the crossovers ive mounted mine under the dash tapped into the original loom with headunit side of the cut wires feeding the crossover and the door side of the wires connected to the woofers output, run a new paired wire for each tweeter to the crossovers- works a treat. btw yeah if ya follow the link in my early post should explain in detail how to dismantle the vent facias
    as for the rear doors just go ahead with a decent set of coaxials should be fine not to mention very quick and easy to do.
    BTW as for any help in regards to parcel shelf or rear doors... ask Phreddy or any the gurus infact who got a sedan and know this area! Hard not knowin that area when i only gots a 2 door ute.
  1. replace VX S2 radio CD unit and back door speakers on wagon
    By jaclyn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2005, 04:58 AM
  2. Replies: 0
    Last Post: 16-10-2005, 06:41 PM
  3. Can I replace globes with LEDs in stock Eurovox deck?
    By holdenrules in forum Car Audio
    Last Post: 28-08-2005, 12:37 PM
  4. new deck to replace stock dbl din
    By troyjm310 in forum Car Audio
    Last Post: 09-08-2005, 05:59 PM
  5. Removing vr front door panels to replace speakers
    By jayseventwo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2005, 01:18 PM
