Results 1 to 9 of 9
Thread: Taking the treble out my sub??
    VL
    Jul 2005
    SA, Mount Gambier
    Default Taking the treble out my sub??
    Hey i have JL 12" sub, Soundstream 480w Xtream Series Amp, Soundstream 6" Xtream Series 2ways and an Alpine HU.
    How do i take the treble out my sub? is anyone aware of what the settings should be on my equipment? or maybe there is a device i can add to remover treble?
    VR Executive
    Mar 2005
    Your amp should have a filter on it, called a low pass filter. Set it to ~80Hz.
    VT
    Apr 2005
    QLD
    is there a built in crossover in the amp? if so, there should be a high and low pass filter switch on the amp, which depending on your switch position, filter the high or low frequencies......
    VL
    Jul 2005
    SA, Mount Gambier
    it does have the hi and low pass filter switches... so i set the low pass to 80, and teh hi?
    EDIT: which does teh bass and which does the treble?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    You don't worry about the high because you're using the low pass filter.
    Low pass means it lets the low frequencies pass through to the speaker and blocks the high frequencies. High pass means the opposite.
    VL
    Jul 2005
    SA, Mount Gambier
    I just went and had another look..
    Soundstream XTA480.4 Xtream Series (4ch)
    Config settings...
    Rear Channels:
    Level (Dial)
    Sub Sonic (Dial)
    BASS EQ (Dial)
    HPF 50hz - 500hz (Dial)
    LPF 50hz - 500hz (Dial)
    HPF/FULL/LPF (Switch)
    So i have the switch on LPF, the LPF dial on 80? and i dont need to worry bout the HPF because the switch is on LPF.
    Also what effect do i get if i have the LPF to 50 vs 500??
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    That's correct.
    The number you set the low pass filter to determines what range of frequencies it will let through. You don't have to set it to 80Hz, but that is generally where most people like it for 12" subs. Vary it and see what sounds best to you.
    VL
    Jul 2005
    SA, Mount Gambier
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    if you put it on 500Hz, it will be pretty much the same as having no LPF
  1. taking gas off 5ltr help please!!
    By walesy in forum V8 Development and Modification
    Last Post: 28-12-2006, 07:31 PM
  2. taking LPG system off one car for another?
    By comtim in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2006, 05:02 PM
  3. Taking A Lover
    By bazcom in forum Jokes/Humour
    Last Post: 09-08-2006, 08:44 PM
  4. Taking on a Council!
    By tdog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-05-2006, 08:00 PM
