i plugged in the rca cable into the back of my HU, and was dissapointed to find that when the hU is put back in the rca cables stop it from fitting. i moved the two bits that hold the HU in back furhter which makes it stick out a littel bit more, but i found that its still about a 7 mm to much. has any one else come across this and had a good way to fix it, other than moving the unit out further
Half a carton and still going!!! Now thats Economy
i had the same problem.You should be able to fix with 90 deg plug rca leads.That fixed my problem![]()
GM Performance Centre
Margaret River
WA
Phone: 0417 094892
south west only EFILIVE Tuner
haha yep it didnt fix my problem!Originally Posted by vyssls1
get some central locking stripping. that will allow you to have the h/u pushed out a bit but also bolted down properly.
but i was using all 3 pairs of pre outs.
what's central locking stripping?? I pulled most of the surrounding off my RCA plugs, like the insulation, because there was heaps of it, really chunky
its and inch wide, 1mm thick strip of mild steel with ~1 inch long slots longetudenly cut along the metal.
look at the h/u install guide on the top of the car audio page.
the 90 deg plug rca leads should fix it had the same problem
you may find that you can use the 90 rca plugs but it still wont go in.....time to hack into the heater box![]()
how do you hack into the heater box? remove and saw a hole out of it and 'glass it up?
whats in there? the heater core? big empty box to piss people off?
who needs heaters?
http://www.jaycar.com.au/productView...Max=&SUBCATID=
There nice an small, an work perfectly
Use them, I got 4 on my Headunit & I'm running Monster Home Theatre RCA's on my car... Why, Because i got them cheap through my bro's work... lol
MaT
Originally Posted by garth
when its f**k'en 1 degree i do!Originally Posted by 12Voltking
also dick smith has a 2 pack of right angle rca's for 4.50! piss off jaycar (for that item at least!!!!!)
i got some nice squishy ones, and the first ones didnt fit even after i had moved the unit out firther, so yeh the squishy ones fit now. but it looks kinda gay how it sticks out so far but oh well. the sound is worth it.
Got any pics? I cant imagine it looking that bad. Well it depends really how far out it is.
ill put some up tomorrow. the main reason it loks tottaly crap is cos the black surrounding doesnt go on for some reason. ha![]()
dont get me started on the surrounding. we have had this pioneer head unit for about a year now and finally thought of a way to get that brackets to line up properly and drill in the right places. i have had the HU out about 10 times and today i finally got it right and now the surrounding fits on properly and looks neat with all even sides (pat on my back)
