Results 1 to 11 of 11
Thread: running power canle for amp in my VP
    Johngh1988 Guest
    Default running power cable for amp in my VP
    Hey ive just bought myself a vp and im putting in my stereo n i cant figure out where the wires come through into the interior behind the glove box to run my power cable for the amp can neone help
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Quote Originally Posted by Johngh1988
    Is your car manual? If it is then there is a grommet on the passenger side for the ecu....depending on the size of the power cable. If its auto then there is a rubber grommet near the brake booster which can be used.....
    Hope this helps.....
    Lets work as a TEAM and do it MY WAY!!
    Johngh1988 Guest
    Johngh1988 Guest
    VS exec
    Mar 2006
    Wollongong
    the rbake booster is the big cylinder sort of thing on the drivers side which is connected to the brake master cylinder.
    do a search for the VS amp install thread i made, at the bottomw of it is how i did the install in my VS which i imagine would be very similar of not the same as a VP
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Default Power Cable Vp
    Gromet under the brake booster, run the cable from the battery thru the gromet, out under the side kick panels or carpet,don't run power cable along with audio cable you will get radio inteference....
    Attached is a pick of a vp commodore brake booster care of www.ebay.com.au
    Attached Thumbnails Attached Thumbnails running power canle for amp in my VP-vp-brake-booster.jpg
    Cheers.
    * RVN 355 *
    Johngh1988 Guest
    91 VN SS 355
    Feb 2005
    WEST SUBS
    not a problem , make sure you connect ur power fuse end to the battery last... & make sure it is tight.
    Cheers.
    * RVN 355 *
    VS exec
    Mar 2006
    Wollongong
    as for leaving the fuse out, i just dont connect the power cable untilt eh very end, but its just the same as leaving the fuse out, more a case of personla preference, because i know to get the fuse out in my car is a PITA.
    Johngh1988 Guest
    Johngh1988 Guest
    successful install n the mtx is pumping hard thanks again everyone
  1. Car Stereo Running Off Mains Power
    By mutchumbo in forum Car Audio
    Last Post: 20-05-2010, 09:26 PM
  2. Desperatly Seeking Power + Power + More Power
    By kezza_4246 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2007, 10:28 PM
  3. Running power cable in firewall "VP"
    By wrx884 in forum Car Audio
    Last Post: 07-01-2007, 11:16 AM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. vx berlina: running power cable & mounting amp
    By dieselplus in forum Car Audio
    Last Post: 03-06-2005, 02:38 AM
