:b: Hey all i own a vt and have installed my alpine stereo system but have come to a glitch. When wiring my amp and sub the amp doesnt seem to work. i have connected the ground, rca, power and remote cable but it doesnt seem to work.
Altho it does work when i split my power wire and connect it to both remote and power inlets on my amp. My power has been connected to the battery and the remote is connected to the back of my deck.
When i connect the power wire to both the remote and power inlets it works perfectlly but of course when i turn my ignition off the amp stays on and im afraid it will drain my battery and kill my amp.
i have checked my remote cable and its not burnt out and is in good condition
My amp is a Alpine MRP-F240
Deck is Alpine CDM 7874EB
Sub 12" S type
Any help will be much appreciated
Hey,
Your remote wire is not working, Do you have a multi-meter to test it?
Or a globe or some sort of light to see if it has power running to it.
It is either not connected properly or the remote output on your deck does not work.
Otherwise if it is getting power at the amp end through the wire the remote input might be stuffed on your amp but i doubt it.
Panther Mica VS Commodore
HP Design 18" Chromies, Lowered, Extractors/Exhaust, Cold Air Intake
(R.I.P - DEFYET - Combo Van)
check that you didn't wire it to the antenna remote wire
its alpine?Originally Posted by vtcarlos
sorry i know i should not post useless shit.but this thread looked about solved.
yeah cheers lads for your help. i checked out where i had wired the remote cable to and it was wired to the blue wire at the back of my deck (electric antena). So i changed it to blue and white and its now all good, cheers again now i can cruise happily with some bangin beats![]()
