As speakers get older they would lose their magnetism correct (due to the hot car environment and all the vibration they are subject to)? How would this impact speaker performance? More distortion? Lower power handling? Etc?
I have a pair of JBL 6x9’s and I’m sure their magnets are not as strong as they used to be and they distort bass more.
cheers
phil
EDIT: they were the first set of speakers got and would be about 4 years old now
Magnets dont lose their their magnetism, The magnet force the magnet exerts will be as strong now as the day you brought it, and for the next 1000 years in the tip.
Its all the other components that make up a speaker that degrade, the cone, coils, glues, pretty much everything else.
Youve prob just blown the speaker, its run its course, theirs nothing you can really do, fixing it IS possible, but no where near worth the money.
Time to get a new set of 6*9's
magnets don't lose their magnetism? who told you that?Originally Posted by ascension24
The only way for the magnetic moment of a particle to be changed is by forcing it to change through the use of a more powerful external magnetic field.
Second year physics.
Gravity is proof that nature keeps getting us down.
its just basic physicsOriginally Posted by dephilile
1995 Manual HSV Clubsport
1991 Supercharged VN Berlina
yeah, i know if you leave a magnet sitting there it's not gonna lose it's magnetism but if you bump it you rearrange the domains (i can't remember if that's what you call them or not) so they are no longer parallel.Originally Posted by stocky
i just did a bit of reaserch and apparently new materials do not suffer from this type of problem. http://www.physlink.com/Education/AskExperts/ae472.cfm
It still doesnt explain why when I put the speakers in and out of the parcel shelf their magnets no longer seem as strong. Originally when I put them in it was just about impossible to get them in without knocking them on the metal. Now its not very difficult at all.
probaby like the voice coils have been a little burnt out
but yeha
im sure magnets dont loose their magnetivity for a very long time as in a few 1000 years
stop being a tight ass n get a new pair
also check your speaker wiring![]()
Maybe you're getting stronger. Have you been eating more?
It's a really interesting question, can't say I know the answer though.
If you wanted, whenever I have a screwdriver that loses its magnetisim at the tip, it gets quite annoying with tricky jobs so I rigged up a simple coil that exerts a strong magnetic force when you put power through the coil. Just put the screwdriver in the inside of the coil for a minute and the tip has it's magnetism back
Sometimes I've gotten carried away with recharging the magnetism and everytime I pick up some of my screwdrivers, it's got a daisy chain of bolts, lugs and other metallic BS all over it lol.
heh i prefer the " manual alignment " spend 5 or so mins movign a magnet over a driver the same way [ like rub down on it ] and it'll get enough magnetic force to hold a screw but not enought to clamp to any metal it touches, great for PC screws ^_^Originally Posted by TehFastyOne
attn Über geeks, i play Second life. Patrio Graysmark.
How do i know this? Im studying mechanical engineering, which is strongly based around materials (metals in particular), things like inter atomic bonding forces etc...
But now that I think of it, the electro magnetic voice coil in a speaker is applying a magnetic force onto the perm magnet (this is how the cone moves). Which could act as a Demagnetizing force on the perm magnet, but only if its a cheaper type magnet. (maybe not cheap, just poor deisgn on the designers half)
But once again these forces by the voice coil on the magnet are always a mirror image because of the nature of the sin wave (music signal) so really any damage being done to the magnet should be cancelled out.
pair of JBL 6*9, 4 yrs old, buy something new.
