Question.
Does the standard Blaupunk headunit (single CD) have pre outs to install an amp.
Thanks
No, but phreddy has a solution to modify it if you want to keep your stock look. Send him a PM
is it possible to run a line level converter to get an amp going?
Yes456789.
ive been looking at line level converters and line out converters is there a difference?? if so what would be a better road to go down?
having phreddy fix up a pre out will have a much better sound. if ur budget is really tight however the line converter will work fine. some amps even have a high level input which doesnt require a line converter
hey mate spend the xtra cash and get the pre amp mod done by phreddy, sounds so much better than the line out converter!
