hey guys im looking at getting a sub and amp for my vn sedan. i already have a clarion dxz646mp(i think thats it) headunit and 2 type S 6x9 in the rear and stocko speakers up front now this was wat i was looking at getting now
AMP
clarion dpx2250
400W 2/1 CHANNEL POWER AMPLIFIER
400 Watts of Maximum Music Power
125W × 2 Into 4 Ohms, 20Hz-20kHz @ < 0.05%THD
200W × 2 Into 2 Ohms, 20Hz-20kHz @ < 0.1%THD
Bridgeable, 400W × 1, 20Hz-20kHz @ < 0.2%THD
Input Voltage Selector
Precise Frequency Selector
Variable Bass Extender; 0-15dB @ 50Hz
Adjustable -12db/Oct. High/Low Pass Crossover, 50-250Hz
Gold Plated Connectors; RCA/Speaker/Power
Speaker Level Input
Dimensions 13 1/4" × 12" × 2 7/8"
SUB
clarion pxw1252
30 CM [12˝ ] SUBWOOFER
1000 watts of maximum music power
500 watts RMS
Dual 4-ohm heat resistant voice coils
Polypropylene electrolytic spun aluminum coated dust cap design
Kevlar/paper composite cone design
Co-polymer composite high excursion surround
Dual strontium ferrite magnet motor dssembly
Hyper-extended vented pole piece
Dual gold plated block terminals
Linear poly-cotton spider with integrated tinsel leads
S.E.T. (Spider Exhaust Technology) cooling
Custom designed die cast aluminum
Hidden screw mounting gasket
or
clarion pxw1251
12" DUAL 2-OHM VOICE COIL SUBWOOFER
1000 Watts of Maximum Music Power
500 Watts RMS
Dual 2-Ohm Heat Resistant Voice Coils
Polypropylene Electrolytic Spun Aluminum Coated Dust Cap Design
Kevlar/Paper Composite Cone Design
Co-polymer Composite High Excursion Surround
Dual Strontium Ferrite Magnet Motor Assembly
Hyper-extended Vented Pole Piece
Dual Gold Plated Block Terminals
Linear Polycotton Spider with Integrated Tinsel Leads
S.E.T. (Spider Exhaust Technology) Cooling
Custom Designed Die Cast Aluminum
Hidden Screw Mounting Gasket
Outside Dimension 12 3/8"
Mounting Depth 6 3/8"
so which would be the better sub to go with the amp?
and is the amp a good choice??
thanks for any help
The PXW1251 would suit that amp as it has dual 2 ohm voice coils. You would bridge the amp and wire the coils in series, so it would be a 4 ohm load to the amp.
Personally, i'd be looking at other brands of sub and amp though. Clarion make great head units, but their speakers, subs and amps aren't of equal quality, in my opinion. How much would you be paying for those?
