Results 1 to 23 of 23
Thread: I'm an idiot...
    knoted Guest
    Default I'm an idiot...
    After spending around 12 hours over a week, borrowing oscilliscopes and other test gear from work, I finally figured out where the incredibly annoying whine was coming from in my new install (even with the engine turned off).
    I was going round and round in circles, the problem was somewhere in the RCA cables. Replacing, re-routing, nothing worked.
    Of course, it's a good idea to earth or remove any un-used built in remote lines on RCA cables...
    Note: It's not an alternator whine, something completely different.
    knoted Guest
    VP WAGON V6
    Mar 2006
    knoted Guest
    Nah, had the CRO on it with a test tone CD, perfect sine wave.
    Think I might go through the tutorials around the place again, as I'm getting a tiny amount of alternator whine (not a priority right now), but it's definitly a problem with the RCA's somwhere. I'm getting perfect HU output, and plugging an mp3 player direct 3.5mm --> RCA cable to the amp works perfect.
    Wierd
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    try singling out each different component to teast them. Find something like an mp3 player, something with RCA outs (you can buy a lead that goes from the headphone jack to RCA's) and plug that into the amp to see if it does it. Then plug it through the RCAs in your car to the amp.
    If it makes the noise when plugged into the other source, its a problem with the amp. If it does it with the RCA's in the car, its an RCA problem. Otherwise its a HU problem
    knoted Guest
    Thanks, but
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    What happens if you earth the outside of the RCA's plug at the head unit end while it is plugged in? What brand head unit is it?
    knoted Guest
    No change. It only seems to make the noise when I plug the sub channels RCA in now, pull subs out stops completely. Just had a go at re-earthing the amps better, no change.
    HU is just a phreddy mod factory unit.
    knoted Guest
    A bit of a summary, this is really bugging me, any more help would be greatly appreciated.
    It's not alternator noise, it's a fairly random squeel that goes up and down and all over the place in pitch, only seems to come from the front speakers. HU RCA output is perfect (tested with oscilliscope), and music, when I turn it up over the squeel (noise doesn't change with HU volume) is great.
    When I d/c either end of the sub channel RCA (passthrough on the jaycar amp) the noise stops.
    Note: I've been doing most of my fiddling with the battery connected, and changing the RCAs around with the HU turned on. I've since gathered this isn't the best thing to be doing... But I have tried earthing as many RCA's as I can, and it doesn't go away, in fact, it gets worse (louder, higher pitch). Do I need to get all 6 earthed at the same time? Does it have to be earthed directly to the HU earth point or anywhere on the chassis will do?
    (I'm actually in the electronics field, but this auto electrician seems very hit and miss )
    All of this is with the engine turned off.
    2004 VYII Acclaim Wagon
    Phreddy modified HU
    Alpine MRD-301 mono amp
    Jaycar 50Wx4 4 Channel amp
    2 x Alpine SWS-1241D 12" subs wired for 2ohms
    Alpine S type 171A 6.5" splits front
    Alpine S type 6.5" coax rears
    4awg to 2x8awg power cables
    8awg earths (4channel to seat bolt, sub to centre rear seat belt bolt, both sanded back)
    Somewhere around 16awg Speaker cable
    Temporary remote lines running everywhere...
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    hold up, if you said the HUis putting out singal no worries, and mp3 to amp is fine, have you tried mp3 down the HU's rca's to amp? or testing headunig from the amp end of the RCA's though i suppose you have. the fact its doign it with engine off is weird imo.
    maybe theres some kind of weird mis-match between the headunit and amp, so they work indipentently but not together? </whimsical suggestion>
    attn Über geeks, i play Second life. Patrio Graysmark.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Quote Originally Posted by knoted
    Thanks, but ...
    yeh, you must have posted while i was typing
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    recconect those unused remote lines and earth them if you can, might make a difference but cant be stuffed going into why
    knoted Guest
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    damn. got any 12ga or something small lying around?? use a few cable ties and run it along the length of the wire, tying it on, tehn earth it at each end. Doesnt matter if its tiny shitty wire too much, wont really be taking any current
  15. #15
    knoted Guest
    Earthing at one end produces a louder constant noise, earthing at both ends seems to cancel out that louder noise, back to my original position
  16. #16
    knoted Guest
    Gave it a go semi, didn't make any difference. I also tried using an RCA splitter on both front and rear channels. Whichever channel (front or back) had both speakers and subs, produced the noise. I also tried earthing both amps to the same point, didn't make any difference.
    I'm starting to think the amp is screwed, but I only bought it a month ago. I have a mate with exactly the same model that I'll try and swap them over and see if it makes any difference, but he's away for another 2 weeks
    I don't really want to take it back and have it gone for a month if it's not definitly the problem
  17. #17
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Do you have a battery polariser, brocky polariser, rust preventer anything like that.....
    I've seen too many installs turn to shithouse because of them putting out a wine at the start of the power cable in the engine bay, trust me, i used to runa 4wd polarizer on my battery, suprisingly enough i rekon this one works but meh people say whatever they want, Just if you have something of the sort, remove it.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  18. #18
    knoted Guest
    It appears as if there is some wierd earth loop happening. Plugging the RCA's only half way in on the sub cable at one end stops the noise.
    Now to make it permanent and so it doesn't fall out...
    I tried just cutting the outer steal bit off then wrapping tape all around the top with the inner nipple sticking through, but the noise comes back. Are there any more sophisticated ways of making a broken earth cable than sticking blue tack all over it? I can't figure out how to pull the connector appart.
  19. #19
    Patrio7's Avatar
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    though i doubt its effects but maybe the center post on the cable is too long?
    or perhaps the outer ring isnt getting the right conduction when fully on, suggesting maybe the amp terminals might be a little mal-formed?
  20. #20
    Supercharged VU SS
    Feb 2006
    The Shire
    try limiting the amount of earth loops. try mounting your amp on wood or something that isnt metal. had to do it the otherday in a VR. sovled the same problem
  21. #21
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
  22. #22
    VY SS
    Aug 2004
    SE Victoria
    yup mount the insulate the h/u, amps and any external processors. pain in the arse!
  23. #23
    knoted Guest
    Well it wasn't the amp earthing anywhere.
    I've given up trying to find the problem, and just wired both front and rear speakers off the front RCA, subs off the rear, and using the amp gain controls for fader
    Too much bloody hassle
  1. ****ing idiot
    By G4orce in forum The Pub
    Last Post: 19-04-2007, 03:07 AM
  2. Help!!!!! i am an idiot
    By wb800 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2007, 09:01 AM
  3. what an idiot!
    By Troy711 in forum The Pub
    Last Post: 02-03-2006, 12:43 PM
  4. First Idiot
    By Darren in forum News/Updates
    Last Post: 27-09-2005, 03:48 PM
  5. The Idiot
    By stretch in forum Jokes/Humour
    Last Post: 14-05-2004, 04:51 PM
