Is it possible to use one of those transformers that you plug into a standard wall socket to test things such as head unit's and lights on cluster/controls etc?
I'm going to change the lights in my headunit and aircon / cluster etc to led's and would like to be able to test them outside of the car.
If this is possible what specifications would I be looking for. eg 12V and 1amp.
Thanks.
yup
sure can
when i did my dash mod i found 12 and earth and used power pack to give power while testing on workbench
as long as its 12v only
And as long as it outputs enough current... Most of them will turn a head unit on but might not supply enough power to run motorised face or accept CD, etc. An old PC power supply works better![]()
ah, nothing like the old pc power supply for running car audio gear on the bench.
specs: 12V and as much current as you can find. high current bench power supplies can be pricey tho. you can usually find a 12V 5A output on pc power supplies if i remember right. that should get you started.
most definetly use an old PC PSU...MY last one I had was good for 9amps.
Sweet. Thanks guys. I think I've got an old PC PSU hanging around.
