Hello, I just put 6x9's in my back shelf and my VN didnt come with rear speakers stock, and I dont have a clue at all where to find the wires for them to extend them to the speaker. Where can it be found!? Thanks
you need to run new wires mate
Do you mean run new ones from the back of the headunit? Becuase the wires for the rear speakers are there, but then they go behind the dash and im not sure to then.Originally Posted by COINERS
i have put speakers in a vn b4. im pretty shore there where no speaker wire because we had to run our own. so i dont know what wires you are talking about :S
Hope you didn't cut any metal from the parcel shelf.Originally Posted by saint_matrix
Gravity is proof that nature keeps getting us down.
Nar, I put the on the front of the parcel shelf where the metal underneath dips a bit lower, and I also put them on the outer edges of the shelf where the wood raises up a bit. So they are just sitting on the metal and they are perfect.Originally Posted by mouce
Same issue mate... there is wires but they do go behind the dash and then dissappear... run new wires, stright from the adapter plug on the HU (if u used one). Will solve all your problems.
Speaker Wire at Jaycar... $0.70c - $1.10 a meter... thats for good stuff... not OMG holy crap thats awsome wire, but enough to get the job done efficently.
Would reccopmend against the magnet being on the parcel shelf.. reccomend spacers. There $30 - $70 approx from autobarn or super cheap.
aZk.
Is sitting the magnet on the metal bad? Because I thought there would be some problem somewhere, but then was advised there was nothing to worry about. ThanksOriginally Posted by azkwazere
it will change the magnetic field a bit.
is the speaker screwed down?
Only into the board, and its a crap job, half of them have already popped out hahaOriginally Posted by garfa
lifting the speakers off the metal and suspending by a psacer on the shelf will stop them from bouncing around against the metal whilst driving, cranking the tunes full bore or both, namely, reduce some wear on the speakers
attn Über geeks, i play Second life. Patrio Graysmark.
