Results 1 to 6 of 6
Thread: american boss amp playing up
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default american boss amp playing up
    hey fellas. for awile now my amp has been doing some wierd. someetimes wen i would start my car up my speackers and amp would just make a popping noise with about 2 or 3 seconds in between each pop. but now it does it all the time. before if i just turned my sterio on and off it would fix it.
    so yeah i pulled my amp apart checked all solder spots and for anything burnout and before putting it back together tried it again. and it worked fine. so i put it back to gether put it in my car but then nothing. not even popping. but it still has green light and power.
    all fuses are fine. all wires are fine. it has power and interals look ok as far as i can tell. any ideas?
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    peel the badge off of it and it'll work 100% better
    j/k sorry. ahem. seriously though
    when you dismantled it did you check top and bottom of the PCB for signs of heat wear?
    also in the process of taking it apart, did you remove the transistors off the heatsink? [black bits "screwed" to somethign or the other, lubed with white paste normally ] they may need chacking to see if one has failed internally
    attn Über geeks, i play Second life. Patrio Graysmark.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    found the prob. it was one of those little black things. ive got it of now. think dick smith wouldd have some
    check my ride
    VY SS
    Aug 2004
    SE Victoria
    i would try jaycar but i doubt it would help. probably look up a big electronic components supplier.
    OR have a chat to an car audio place (excludes jb and strath).
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok ive tried everyone in town and no luck so far. anyone have a web address of a place were i may be able to get it. or any phone numbers and the names of places in victoria that may be able to help me.
    also ill give u the details of what it has written on it and if anyone is stripping a amp can u see if u have one the same. thanks
    its no bigger then my finger nail
    3 wire strips coming out
    FMG 24R
    09 08
    check my ride
    VY SS
    Aug 2004
    SE Victoria
    mate just go to a car audio place if they cant get the part they will know someone who can fix it. no one here willl be pulling apart an american boss amp model ..........
  1. Hello from the US. Sorry for being American.
    By bigjoe in forum V6 Development And Modification
    Last Post: 30-01-2008, 01:33 PM
  2. american boss amp? any good (12voltking?)
    By phat_com in forum Car Audio
    Last Post: 19-12-2006, 05:42 PM
  3. American Model
    By svx002 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-05-2006, 01:05 PM
  4. Is CA Boss the same as effects Boss?
    By semi in forum Car Audio
    Last Post: 08-01-2006, 02:30 AM
  5. 5.1CH American BOSS Amp for sale
    By vy_pete05 in forum Parts And Other Items For Sale
    Last Post: 12-11-2005, 10:45 AM
