[URL=http://imageshack.us][/URL
hey guys n girls i was just wondering about amps what would be the best for these 750watt audiopipe 12" subs? i dnt want to spend to much but i want something to thump the subs? any ideas?
response gets the thumbs from me.
budget?
What is the RMS rating on those subs? And what impedence voice coils they have? You need to know that before picking an amp.
the guy im buying them off recons the audio pipe GD3001 2000 WATT MONO BLOCK DIGITAL AMP
OUTPUT 1000 WATTS RMS @ 1 OHM (FULLY 1 OHM STABLE ) CERTIFIED BY IASCA
TESTED TO CEA (USA) STANDARDS, DISTORTION LESS THAN 0.5% THD.
MASTER SLAVE FUNCTION AT 4 OHMS. SIGNAL TO NOISE RATIO 60dB.
RCA INPUT SENSITIVITY 0.2 - 5 VOLTS, INPUT IMPEDANCE 20 K OHMS
LOW PASS FILTER 40-250 Hz / 24dB OCT, SUBSONIC FILTER 10-50 Hz / 24dB OCT.
FREQUENCY RESPONSE 10-300Hz. / 4G INPUT
the subs are 750watt rms 1500watt max
any help
great and ask the guy the impediance and power rating of the subs and how they are wired. (parallel or series).
Originally Posted by brohawk
you wanna change your signature please? that's not nice
i am the god of britany spears womanizer on just dance on the wii
look garth its a song ok ive taken alot of flack about it an i like it coz it fits me and if u dont like me u dont like me i dnt care thats basically what it is saying but its a line from a song so dont be so uptight. im NOT sying ne1 who reads this should suck my dick. do u know my reputation? do you know me no you dont.
so relax
Dude, that is the site admin asking you to change your signature so that you don't offend people. Do as you are asked and don't be a tool.
i got asked to change..... "i dont care what she says...if it fits its the right hole" and did so gracefully....pull ya head in brohawk, your not untouchable because its a song lyric....*shakes head*
Loudness - the intensity of sound!
www.globalhardstyle.com
check it...
hehe, someone is going to get owned (or banned!)
by the way my name is garth as well, so go **** yourself! (if that was intended at me.)
a responce 2x150W rms will do you the trick, drop it down to 2 ohms which would leave you with a fair amount of power per speaker....
dont get confused by the 2x150W rms, when bridged its actually around 500W rms, then if dropped to 2 ohms should leave you with 700-800W rms so thats atleast 350-400W rms per channel, that leaves you with plenty of head room to play with
people say medium quallity, but in reality,
its a POWERAMP... with a BASIC EQ in it......
with the right EQ setup it can sound as SH*t or as good as u want it to...
its also about tuning your system, most people dont have a clue about it and claim a product is crap because they dont understand how to make it sound good, ive "better" quallity amps before and they'res not that much of a diffrence
That Jaycar amp isn't 2 ohm stable when bridged... I've seen the old model cook when wired to that load.
tuning isnt a problem i play music n install car stereos then tuning them and ive been doing it for years so its piss easy
but its all good i spoke to my boys at my local stereo place they will hook me up with my new hed splits and 2 1000wat kenwoods for cheap. n ill just build the custom box that i was going to. so when it starts comming together ill post up some piks system should thump when im done.
cheers every 1
