Results 1 to 15 of 15
Thread: VT wiring harness??
    VT Berlina
    Mar 2006
    Default VT wiring harness??
    Just bought an Aerpro wiring harness to do my headunit in my VT berlina and noticed that it does not have a black ground lead on it. It's got all the other relavent colours but no grounding lead.
    Is it supposed to or does the grounding wire not run through the harness??
    VY SS
    Aug 2004
    SE Victoria
    run a new ground. stock grounds can (and are) not as good as the ones you make yourself.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    I have a VT Berlina and used a wiring harness... I can't remember what colours each wire was but I didn't have to run a new ground or anything.
    VT Berlina
    Mar 2006
    yeh.....was thinking i should just run my own ground.
    What about the power antenna wire though?? The Aerpro harness i bought doesn't have a power antenna lead on it??
    I'm unsure what to do with the power antenna wire from my headseat loom as it doesn't join up to the Aerpro harness
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Is this the loom you got? It is the model 711784H which suits VT Commodores. It has a black earth wire. I can't remember about the electric antenna wire because my head unit (Pioneer) doesn't have electric antenna wire, just remote wire so it was connected to the blue wire, as far as I remember.
    VT Berlina
    Mar 2006
    I bought the AP1784H (below) because it said "connects to OEM harness to enable connection to aftermarket head unit."
    Did I by the right one??
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yeah, sorry, my mistake... I don't know what the point of the one I listed is.
    Do you still have the packaging? Mine said what each wire was and there was an earth. I tried looking under my dash but I couldn't see the wires unfortunately
    VT Berlina
    Mar 2006
    yeh still got the packaging.....but not all the colours listed on the back or on the loom eg
    pink=mute....not there
    black=ground.....not there
    blue=power antenna.....not there
    orange=illumination....not there
    orange/white=dimmer.....not there
    i'm thinking maybe the antenna wire from my h/u goes to the blue/white remote on the wiring harness as there is no blue power antenna on the harness
    i wouldn've expected a grounding wire though
    thanks alot for the help so far mate.....really appreciate it
    VT2 Berlina
    Aug 2005
    Hi dbun,
    Went through some pain getting the antenna working on my VT, but is actually quite simple. Here is the guts of it.
    1. If you use the wiring harness as most people suggest, then it will connect the blue wire from the HU to the Yellow/Red in the wiring harness. This tells the antenna control unit that the radio is on. It doesn't supply power to the motor, this comes directly from the battery.
    2. If you had the antenna up when you took out the old HU then it should go back up to that spot when you hook up the new HU.
    3. If you had the antenna down when you replaced the unit (like I did) then the antenna stays down. Read on to find out how to fix it.
    There are 2 wires in the harness to control antenna UP (Light Blue) and DOWN (White). To control the antenna height, connect EARTH to either the UP or DOWN wire. Not 12V. Once you have it in the spot you like, simply leave them unconnected in the plug and the antenna will return to that spot when the HU is on and go down when the HU is off.
    If you want to control it, you will need to put a 3 way rocker switch somewhere to switch EARTH to either wire.
    You should be able to find wire colours and a schematic here on the forum. Both helped me heaps but feel free to email if you have any questions.
    BTW I ran a separate earth for the unit.
    Muttley
    VT Berlina
    Mar 2006
    Thanks for the reply Muttley
    just with the antenna.....i thought the commodores automatically retract the antenna when you turned of the car?? So do you mean you have the antenna physically up when you remove the H/U??
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Yep, before changing head unit. You set it to full height, then when you put the new head unit in, it will automatically go to full height.
    Here for instructions on the rocker switch.
    VT Berlina
    Mar 2006
    I'm beginning to think i may have gotten a dodgey loom........mine is definitely missing the black ground lead and i can't find a wire to connect the antenna cable from the H/U to the wiring harness........the only free cable on the harness is a blue/white lead which is labelled as 'remote' but this is supposed to be run to the amps is it not or am I mistaken??
    VS Acclaim
    Jun 2006
    if im not mistaken isnt the blue and white lead for the auto antenna generally... it is also used as the remote turn on for any amps you may have.
    VT Berlina
    Mar 2006
    ^^ yeh i was thinking that.......cause they have a blue/white lead on the harness labelled as 'remote'....i think it is the remote for the arial to let it know it's on.
    Will still go back to autobarn tomorrow and see if the other harnesses have a grounding lead on it though........just to know if i got a dodgey one or not even though i can't return cause i've soldered the connections already lol
  15. #15
    antiskeptic Guest
    hey man, yeah its simple you do have a dodgey loom, i brought one for my vt berlina and i had the earth wire, power antena, dimmer etc... hooked it all up worked first time no probs....
    take it back get a swap over
  1. Wiring Harness
    By SinisterVY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 06-05-2007, 11:28 AM
  2. Vs Wiring Harness
    By DJ Majah in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-02-2007, 03:45 PM
  3. wiring harness
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-11-2006, 07:50 PM
  4. VR wiring Harness
    By dutche in forum Electrical Wiring / Questions
    Last Post: 13-04-2005, 02:59 PM
  5. Wiring Harness Guy
    By vkberlina in forum Electrical Wiring / Questions
    Last Post: 24-03-2004, 12:32 AM
