Results 1 to 7 of 7
Thread: Speaker sizes for VZ ute
    TDK14U Guest
    Default Speaker sizes for VZ ute
    Hi Guys,
    I just recently bought a new VZ SS Ute. I am looking at upgrading my speakers. Can someone please answer the following questions:
    1) Are the Speakers splits are coaxial
    2) What size are the speakers (i just want them to be directly swapped)
    3) If they are splits, where are the current tweeters.
    Many thanks
    VZ Monaro CV8
    Jul 2005
    w-sydney
    i believe they are 6" splits not 6.5" - the tweeters are under the vents at each on the dash
    there are no cross overs with the standard speakers by the way
    - b a r b s -
    Check out my Monaro
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    Care to take a look
    VZ audio
    ive done an extensive writeup on replacing speakers (woofers n tweeters) for the fronts as i did first hand meself with my ute - fitted a pair of JL 6 inch splits
    anywas to simply answer your questions... front doors are splits with 6" woofers - no xover just a filter capacitor on the factory tweeter,
    and the tweeters are located under the vented area - article will explain in detail how to dismantle for access
    see if thats any help!
    TDK14U Guest
    Hi Guys. Thanks for the help.
    So after reading the above thread, the stock speakers are 6", but 6.5" can be fitted. How much modification is needed to fit the 6.5" speakers, is it a big job? I don't want to modify the cartoo much.
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    depends on the speaker your putting in, some pioneer ones can be screwed straight in no problems, others require cutting away the back end of the door pod
    attn Über geeks, i play Second life. Patrio Graysmark.
    Turismo Blue 2005 VZ Storm Panelvan
    May 2005
    Quote Originally Posted by Patrio7
    how about these puppies
    http://www.jaycar.com.au/productView...=&SUBCATID=602
    VY SS
    Aug 2004
    SE Victoria
    if they do need any cutting it will only be minor.
  1. speaker sizes - vt
    By garfa in forum Car Audio
    Last Post: 27-11-2007, 09:06 PM
  2. VY + Speaker Sizes
    By Gobbles in forum Car Audio
    Last Post: 18-07-2006, 12:42 PM
  3. speaker sizes
    By FINCH in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-03-2006, 03:31 PM
  4. VT speaker sizes
    By VTPREDATOR in forum Car Audio
    Last Post: 19-01-2006, 09:07 PM
  5. Speaker Sizes In Vx Wagon
    By VXWAGMAN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-01-2004, 05:12 PM
