Results 1 to 20 of 20
Thread: Speaker repair
    Black VZ SV6
    Dec 2005
    Arrow Speaker repair
    I have a pair of Pioneer (TS-C160R) splits residing in the front doors of my VZ. Recently i noticed the passenger side door woofer has cut out completely, but if i put the volume high i would get some distorted audio out of it. I have removed the woofer and inspected it, and it seems the problem is the negative wire that travels from the terminals to the cones has become weak and only conducts when it is held in a certain postion. Considering the cost of these splits, i would love to have a go at repairing it rather than replacing them (around $300, meh). It seems the break in the wire is pretty close to the terminals, so i considered carefully coating the break in solder. But im not sure how this would hold up....
    I would appreciate it muchly if i could get some opinions on this matter.
    Thanks heaps!
    Drive it
    Like ya stole it!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Take them back to store, Pioneer will assess and replace if it wasn't your fault
    Black VZ SV6
    Dec 2005
    i purchased them online, so that might be a bit hard...
    what do you think about attempting to repair them?
    Drive it
    Like ya stole it!
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    I'd attempt to repair them, There not working currently, I dont think it can get any worse...
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    Don't get your iron to hot, dont keep the iron on the tinsel leads for a long period of time. Get it on...get it off. Have the solder already on the iron.
    Don't overdrive them again.
    Black VZ SV6
    Dec 2005
    okay, thanks for the tips 12volt.
    i'll let you know how i go
    Drive it
    Like ya stole it!
    Tasmaniak's Avatar
    car
    Apr 2005
    generaly that repair is only good for larger speakers like subs, but it will certainly work for 6"
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    i did the exact same thing to my pair of 160's too. Got someone else to resolder it coz im shit at soldering and paid about 10 bucks. All good since then
    Black VZ SV6
    Dec 2005
    Okay, so i attempted the repair. Turns out the break was very close to the terminals, so close that i had to strip away the white silicone (that is put over the join) so i could make the solder fuse. The wire was only holding on by about 3 strands of wire! I tilted the speaker away so that if any solder fell it wouldn't land on the cone, coated the iron tip in solder, transfered the solder to the break and smoothed it out nicely. Anyways, the repair was successful and the woofer sounds like new again. Thank for your help guys!
    Drive it
    Like ya stole it!
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The only problem with resoldering tinsel leads is that solder seeps up the lead when hot and will cause it to snap in the future, but at least it's fixed for now
    Tasmaniak's Avatar
    car
    Apr 2005
    StoneX is right it's only a temporary repair. But it's running again and may do so for years.
    VT COMMODORE 50th ANNIVERSARY
    Jun 2006
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    The solder seeps up the inside of the lead WHEN YOU SOLDER IT, not when playing the speaker. This makes the lead stiffer than normal and will eventually lead to it snapping again.
    Jun 2006
    hyaha oops OHh yeah
    n the heat could also melt the cone of the speaker too :S that wouldnt be nice
  15. #15
    VY SS
    Aug 2004
    SE Victoria
  16. #16
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Nah, no matter how quick you are, it still seeps more than when it was originally done.
  17. #17
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by StoneX
    So why do you think some top repairers wrap desoldering braid around about 3mm up the tinsel leads they solder on, works wonders... I've seen the repair done with it, an the only stiff bits are exactly where the repairs are, It's incredible work.
    MaT
  18. #18
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  19. #19
    VY SS
    Aug 2004
    SE Victoria
    yeah i realise that i was just talking about the melting of the speaker cone!
  20. #20
    Tasmaniak's Avatar
    car
    Apr 2005
    Quote Originally Posted by HoZy
    MaT
    So why do you think that the TOP repairers of speakers don't solder the tinsel leads instead they replace them? Because it isn't incredible work. Infact all it does it lowers the surface area of the solder. Fact still remains is that it has a stiffened point.
    If its wortht repairing then it's worth repairing right the first time.
  1. Should I sell my VT or keep and repair
    By VTS07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-05-2007, 08:08 PM
  2. WTD - VS etc Speaker Door Pod Speaker Grills
    By lil_oneblue in forum Swap / Wanted to Buy / Trade
    Last Post: 08-01-2007, 08:38 PM
  3. Rim repair
    By HIROLLA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2006, 08:38 PM
  4. speaker repair/ 4" power?? 130rms
    By stock_vl in forum Car Audio
    Last Post: 01-10-2005, 01:14 PM
