Results 1 to 4 of 4
Thread: amp problem
    VT Berlina
    Mar 2006
    Default amp problem
    Just finished hooking up my gear and went to test it but the amp did not come on.......it was in diagnostic mode. I unplugged everything except the power supply to the amp and this time no lights came on at all. When i tried to plug an RCA plug into it the diagnostic LED came on.
    I think it's a power issue though because it does not go into 'power' mode with only power, ground and remote plugged in.
    If i put a multimeter on the power and ground cable (not plugged into the amp) i get about 12V. When i plug them into the amp and measure across the amps terminals it is about 6V......dodgey fuse maybe???
    And also is the remote trigger 12V as well.......haven't measured yet but not sure what it is supposed to be
    EDIT: when i used the multimeter it was more like 11.98V
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Quote Originally Posted by dbun
    Sounds like a high resistance to earth (bad earth) to me.....
    Check your earth with your multimeter and see what it reads it should be near zero.
    Place one probe on the earth cable at the amp and the other probe on some metal part of the car, should be a part with no paint, or anything around it just metal.....
    See how you go with that ..... cheers
    Lets work as a TEAM and do it MY WAY!!
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Above +1 bad earth I reckon too. Or possibly corrosion or other nastiness in terminals/fuseholders causing a high resistance path in the supply line.
    If you have close enough to 0V across your earth cable as VQXTC has suggested, the voltage drop is occuring somewhere between the battery and the amp's power input. Inspect the above items.
    Cheerz!
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    when you say you unplugged everything but the power, did you leave the remote wire connected?
  1. Amp problem
    By Gunns VC in forum Car Audio
    Last Post: 16-10-2007, 03:33 AM
  2. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  3. Sub Or Amp problem???
    By calais_cruzin in forum Car Audio
    Last Post: 17-01-2007, 01:44 PM
  4. Another Problem
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2006, 01:03 PM
  5. Problem after problem!!!!!
    By Swerve103 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-04-2005, 06:24 PM
