Results 1 to 25 of 25
Thread: 3000rms, What awg/guage wire should i run?
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    Default 3000rms, What awg/guage wire should i run?
    Hey, im going to be running around 3000wrms, what size wire should i run for power and ground?
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    throw in some 0awg.....
    have a 0awg - 4awg distribution block.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    SMIT's Avatar
    Aug 2005
    That was my plan, just wanted to make sure i was doing the right thing. and about the ground, just run 4 awg from the amps to a grounding point?
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    yep, 4awg from amps to a grounding point Car chassis/Body
    MaT
    SMIT's Avatar
    Aug 2005
    Tasmaniak's Avatar
    Tasmaniak is offline Not a valid input....
    car
    Apr 2005
    2ga or 1 ga would also carry the load but it doesn't have the wank factor that you are after.
    burnz's Avatar
    burnz is offline dah dut dut da dah
    2010 CRUZE Diesel
    Jun 2005
    springfield
    Quote Originally Posted by kinkbike_rider
    welding cable
    Research has shown that men usually sleep on the right side of the bed.
    Even in our sleep we happen to be right.
    Powered By Garrett
    davey g-force's Avatar
    davey g-force is online now I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Quote Originally Posted by burnz
    welding cable
    LOL!
    Jumper lead cable! (I've actually done it before!!)
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by davey g-force
    LOL!
    and there is a problem with that?!
    as long as the cable isn't sobid core, it should be fine.
    go with 2ga. and if need be run 2 lengths of it. i dare you to find anything near the $12pr meter of the jaycar 2ga power cable. even if you run 1x0ga it would be more expensive. (unless you can buy it cheap).
    HoZy's Avatar
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    See if you can find the website to CrazyCables Australia, He used to sell 0ga for $13pr meter.
    MaT
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Tasmaniak's Avatar
    car
    Apr 2005
    only $13 postage?
    grafxworld's Avatar
    grafxworld is offline KLRBASS
    VT GTR EXEC S1 - SOLD off
    Feb 2005
    I agree 13 bucks postage for that heavy roll of wire ?
    might want to check that again
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  15. #15
    SMIT's Avatar
    Aug 2005
  16. #16
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    how about a reactor in the boot?? Would solve the cable problem at least..... Might cost just a bit more tho....
    (sorry, just being fatuous)
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  17. #17
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by Phreddy
    so would you do a rod change every oil filter change? and then change the coolant in the radiator and the reactor?
  18. #18
    VS Acclaim S2
    Nov 2005
    i bought 2 rolls of 15m 0 awg from crazy cables at an excellent price. Got them for $72 for the first one and $70 for the second as the first one only had one other bid and the other had no other bids. Postage on the first was $20 and i took massive advantage of their policy of only extra $2 postage for additional items (bet they weren't expecting people to buy 2 big rolls). All in all, 30 metres of 0 AWG cable for a grand total of $164 (equates to approximately $5.47p/m). - beats $12p/m for 2 gauge from jaycar ey?
  19. #19
    VR Berlina auto s2
    Aug 2005
    the shire!
    just curious.. what did you use 30metres for? can this be used for relocating a battery?
  20. #20
    VS Acclaim S2
    Nov 2005
    well actually i went halves with a mate, so i've got a 15 metre roll and he's got a 15 metre roll. I bought it primarily because of the excellent price. I've actually already got a 0 gauge run to the boot for a couple of amps distributed (when my other amp finally gets here). I plan on using this first and foremost just for upgrading the wiring under the hood (grounding etc). I'm sure you could incorporate it in a dual battery setup but i'm aware there's other pieces you'd need for the setup (buzzwords like "smart solenoid" ring a bell or two). I pretty much got it a) because i can use it and gives me PLENTY of cable for any heavy drain electrical applications i may add with future expansions and b) because at that price even if i only use a bit i could probably sell it for more than i bought it for. Cheers, Bryce.
  21. #21
    VR Berlina auto s2
    Aug 2005
    the shire!
    cheers thanks, i was looking at getting some for the battery in the boot idea.
  22. #22
    VE Calais-V 6.0L
    Aug 2005
    Hastings
  23. #23
    VS Acclaim S2
    Nov 2005
  24. #24
    Apr 2006
    You're planning to pull 250amps continous?
    I'd be going for a second battery with the little module that picks which battery to charge!
    Most batterys are only set for 200AH (They'll push 200amps, for one hour, and go flat!)
  25. #25
    Tasmaniak's Avatar
    car
    Apr 2005
    Quote Originally Posted by MBS206
    mmmmmMMMMMMMmmmmmmmmm I can feel the Hall Effect from here...
  1. My Fuel Guage is out...
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-02-2007, 03:56 PM
  2. fuel guage
    By wal in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-01-2007, 05:45 AM
  3. need rpm guage!
    By kwik6 in forum Swap / Wanted to Buy / Trade
    Last Post: 24-03-2006, 09:30 PM
  4. orange wire and orange white trace wire - which is "+", which is "-"
    By Brycestro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2006, 09:28 PM
  5. Replies: 4
    Last Post: 14-09-2004, 07:44 PM
