Hey all, especially to any Thiele-Small afficionados out there.....
I have a small conundrum, in that I'm wanting to use a particular driver in a ported sub box design - it's a DVC driver, twin 2 ohm coils - the Thiele-Small parameters listed for the driver relate to single voice coil usage, but I'd like to use the two coils in a series hookup for a 4 ohm load impedance. (there's no parameters listed for dual coil mode in any configuration, series or parallel)
My question is this - is there a fairly standard conversion/calculation to derive the dual coil parameters from the single coil figures? I know that BassBox Pro can do this for you on the fly, but I'm not using that modelling program and don't really want to spend 150 bucks to be able to!!
(although I do have a brand new VY/VZ short-shifter stick for the V8 six slotter which I'd swap for it!!)
Anyhow, any help would be appreciated. If you read this and go "Huh??" thanks for looking at the thread anyways.
Cheerz!![]()
New look ASR Website online now!!
www.asr-audio.com.au
Interior lighting and audio specialties
for VT/VX & VY/VZ Commodore / Monaro
NOW VE DASH LIGHTING CONVERSIONS!!
PLUS TECH2 DIAGNOSTIC SERVICES
JBL Car Audio dealer
[QUOTE=Phreddy]Hey all, especially to any Thiele-Small afficionados out there.....
Cheerz![/QUOTE
Hey there Phreddy,
I have Bass Box Pro so send me the thiele small's and even the driver model number and make and i will key them in then let you know the results if you like......cheers
Lets work as a TEAM and do it MY WAY!!
G'day VQXTC - we meet again!
Mate, that'd be legendary! Thanks for that, single coil parameters as follows....
It's the Response CS2366 by the way - the 10" metal coated cone jobby.
SPL - 87.2 dB/W/m
Vas - 66.085 litres
Re - 1.3 ohm
Fs - 23.7 Hz
Qms - 3.976
Qes - 0.382
Qts - 0.348
Xmax - 10mm p-p
and just in case it matters, voice coil daimeter is 65mm.
LOL! If I can push my luck a bit furthercould you do a port calc for me?? I'll have a box volume of pretty well spot-on 25 litres (after subtracting braces and back volume), and I'd like to use a port diameter of 58mm if possible. (wanted to use the flared ones that Jaycar have)
Thanks again Mate - if you can post at least the parameters for dual coil operation in SERIES mode, I can run it through the box modelling proggy that I have, maybe compare the results.
Cheerz!
Huh??Originally Posted by Phreddy
I see you're at it again Phreddy! Good luck mate...![]()
LOL! Thanks Dave - yep, another job....
Will reply to your e-mail shortly too - that's a bloody oddball one that!!![]()
Cheerz!
Hey there Phreddy,Originally Posted by Phreddy
My apologies but I have been on holidays for 2 weeks so i havent been near a computer for a while....
I will get that done for you very soon and post the results cheers.....
No problem Mate - I appreciate it.
(had my arse hangin' out on other things anyhow!)
Cheerz!
Ok phreddy I finally got around to doing what you asked.....Originally Posted by Phreddy
Re 2.6 ohms
Qes 0.191
Qts 0.182
I also done your port calc for you and the results are as follows.....
Excellent! Thanks Mate, I appreciate that.
I'll let you know how the box goes!![]()
How are you going with that box? Just thought I would check up and see everything is going......
Did you understand that port calculation i did for you? Hope it all made sense....
Cheers.........
LOL! Thanks XTC, but I've been as busy as a one-legged man in an arse kicking contest lately!
Have the box plan drawn up, the saw hasn't turned a revolution yet - I'll get on it soon though....
Oh, and the port calc made perfect sense BTW. Thanks again Mate - will definitely report on the results.
Cheerz!
