Results 1 to 23 of 23
Thread: Subs in wagon
    VN Statesman Wagon( written off) VN calias 5 speed
    Mar 2006
    Default Subs in wagon
    Which is the best way to have a 12 inch sub facing in a wagon.
    I notice every one is putting them in the rear area but they put them facing towards the tailgate, wouldn't it sound better to face them towards the front?
    VN SS. HSV VT Calais
    Dec 2005
    Nsw - Taree
    depends, this has always been a weird subject for me. Example, when i was running a single 12in rockford P2 it sounded better facing towards the front of the car, it was a more aggressive bass. BUT my twin Fusion 12's sound better facing out, they sound dirty facing towards the front. But it could be different in a wagon, if i had a wagon i'd be puttin it against the back seat and facing towards the boot OR having it sideways, like pointing to the right hand side of the car .... yeh id do that actully lol
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    theres a big long thread about it on here somewhere. face the subs forwards and backwards then see which you like better.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yeh, try it yourself and see what you think sounds best. mine are facing the tailgate, coz if it was facing the front you wouldnt see them very well unless u look from inside
    Dec 2005
    Nsw - Taree
    Quote Originally Posted by hakhawk
    wouldnt see them? who cares?! i dont know about u guys but i dont have subs so ppl can see them
    VH commodore SL wagon 253
    May 2006
    the shire sydney
    i thought facing them towards the tailgate was technically the correct way? the length of a soundwave from a sub was long or "low" enough so that by the time it had left the sub bounced off the back of the car and hit the passengers it was at its highest or "most powerful" point? correct me if im wrong but that is what i belive right now
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by BigDaz
    and hence why i dont want a wagon!
    hakhawk's Avatar
    Jan 2005
    Mar 2006
    thanks guys, thats helps heaps, i think i'll face them towards the tailgate
    looks better that way
    Driftwagon Guest
    I have mine facing the tailgate and they sound better this way, but it is all about experimenting with there position, where the ports are etc, trial and error is the best way but use various tracks to test cause it might bet more boom facing forward, but less shake rattle and roll
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    I put mine facing the back seat about 2 inches away from it. Keeps the backseat passengers happy It prob isnt the best way to do it but i didnt want people to see it from the outside as the sub-box is enclosed in another box which holds all the audio gear in the back
    as seen in the avatar ^^
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    facing it to the back generally makes it louder, something to do with wavelengths and path differences or something
    VS Acclaim 3.8
    Jul 2006
    Facing them to the rear creates a pressure wave going backwards that pulls more base and sound clarity from your front speakers. Otherwise you just end up sitting in the middle of a cross fire of speakers firing sound in all directions, not so bad in a large concert hall but very bad in small spaces with hard and soft objects eg glass and seats. The speakers end up working against each other - the cones pump sound toward each other and kind of create a cancelled out wave of pressure.
    Imagine your at a concert and the band in front of you and singer on stage raised up in front of you. This is the ideal enviroment you are trying to re-create in your car as best as possible.
    Mounting small tweeters in the roof above the windscreen or dash (with independant controlled volume level control) will enable you to re-create this stage more accuratly than having the singers voice coming from below your elbows somewhere.
    Considering this stage effect, you wouldn't have the band and singer on stage in front while the base player and drum kit are set up behind you pumping sound into the back of your ears. This creates phase shifts in sound pressure waves and unwanted bounce back etc. in other words crap sound with wandering base that seems to pump out a muddy slow response instead of a smooth sharp punch correctly in time with the song.
    Having all the sound going in the same direction as much as possible, I believe is the simplest way to explain the best envirometn for your ears to hear the song the way it was intended the day of recording.
    I've been building car stereo systems for over 15 years, its been a hobby that I became slightly obsessed with
    blaze's Avatar
    blaze is offline ridin dirty
    SILVER BULLET
    Jul 2006
    bunbury
  15. #15
    VTII Acclaim
    Jul 2005
    NSW
    Depends on lots of variables, including the local air temp and pressure (alters the speed of sound). The idea is to get all the sounds from the different speakers to arrive at the listening position at the same time and in phase, as explained above. Because of the length of the wavelenth of low frequencies sometimes it is necessary to increase the path length. So if you want the best sound then you should move it around to find the best spot. Practical considerations will obviously come into it as well. Most wagons i have seen have them facing back. My sedan if far better facing back as well.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    Dynamat Extreme/Dynaxorb
  16. #16
    VK wagon
    Aug 2006
    NZ
    Subs or a sub mounted in the tailgate would be cool, just have to be careful not to slam it shut...
  17. #17
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by nizmovk
    not possible
    My (ex)Ride
  18. #18
    VS Acclaim 3.8
    Jul 2006
    Default Um.....why not?
    Quote Originally Posted by azzfox
    not possible
    You say not possible. Why not?
    I've been given a challenge now.......
    I'll be back on here in a few months with pics
  19. #19
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
  20. #20
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by TheJack
    1. Is the tailgate thick enough for one/two?
    2. Is it hollow? If so it needs to be the exact desired volume (space) and sealed perfectly.
    3. HAVE FUN
    My (ex)Ride
  21. #21
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by kritical
    i wanted to put a 10''sub on me parcel shelf of my vl is that poss?
    yes it is possible ive seen a vl with a sub in the parcel shelf(not sure bout the size) it was mounted upside down.
    Adam
  22. #22
    VY SS
    Aug 2004
    SE Victoria
    the cops wont give a shit as long as you dont cut any structural metal! so inverter would be easier.
  23. #23
    MY06 VZ SS 6.0 TUR(i)SMO
    May 2006
    Hastings
    Quote Originally Posted by garfa
    if your rear windows were as dark as mine you wouldnt be able to see them anyway.
    because i cant.
    and my windows are perfectly legal.
LinkBacks (?)
  1. 01-01-2009, 06:52 PM
  1. FS: 2x 12" Pioneer VCCS Subs in Custom Box! Silver Cone Subs!
    By 1991_Vn2nV in forum Parts And Other Items For Sale
    Last Post: 06-01-2008, 08:27 PM
  2. Manual VT wagon or VX wagon + conversion?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-07-2006, 11:09 PM
  3. vs ute subs
    By north kb in forum Car Audio
    Last Post: 14-06-2006, 10:11 PM
  4. subs? sub box? HELP
    By stock_vl in forum Car Audio
    Last Post: 19-02-2006, 12:19 PM
  5. JL subs
    By VX_GIANTZ in forum Car Audio
    Last Post: 11-01-2006, 10:18 PM
