Results 1 to 16 of 16
Thread: NEW sub wiring help
    VE II SV6 Sportwagon
    Sep 2005
    Exclamation NEW sub wiring help
    g'dai guys. just after some help in the wiring of my system,
    i've got a single 12" running off a two channel (bridged, running 800wRMS) unfortunatly, i've blown the subs voice coil (was second hand to start with) though ive been told i have to turn tha gain down, as the sub is only 550rms, single voice coil. though also wana no if the wiring into the sub i run is correct. its a dual lug terminal on the sub, so two pos two negs, im just running the wires to the outer pos n neg, is this correct?? cause i really dont wana blow another sub.
    cheers
    vp calais
    May 2006
    adelaide
    yer that sounds rite but if its single voice coil it should only have 2 terminals
    VY SS
    Aug 2004
    SE Victoria
    you have blown the driver but want to know if you wired it right? what???
    it does not matter because the driver will be useless now.
    heres a thought, either change the amp so you make it harder for yourself to blow the driver or get a new sub suited to the amp, be it bridged or normal.
    silly boy.....
    Sep 2005
    i've already bought a new sub mate, the other one was second hand, so chances are it was already thrashed.
    its an audiobahn system, and i spoke to the audiobahn guys at autosalon, and this is the sub they told me suited best.
    and i know the sub is buggered now, hence y i bought a new 1, though i was only asking about the wiring so as i dont blow a second sub within a couple of months. ? cheers
    VY SS
    Aug 2004
    SE Victoria
    the wiring wil not effect the ablility to blow the sub again. the way its being over driven will though. why dont you run the sub from the amp un-bridged?
    VTII Acclaim
    Jul 2005
    NSW
    To better answer your question,
    What are the model No. of your sub and amp?
    Your new dvc sub has two voice coils hence two sets of terminals. Normally, these must all be connected to operate the sub properly. Need to know what the sub and amp are to help.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    Dynamat Extreme/Dynaxorb
    Sep 2005
    g'dai phree,
    its only a single voice coil sub, but the audiobahn has dual terminals, not sure y.
    its a audiobahn A8002T amp (running it bridged) and a audiobahn AW122N sub. the blown sub is audiobahn AW120T, also a single voice coil, and the old one was 500wRMS and the new one is 550wRMS.
    cheers
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    did your first one, the one thats blown, have 2 sets of terminals?? Whats the model niumber for the new sub? same as the old one?
    VTII Acclaim
    Jul 2005
    NSW
    Two sets of terminals for one voice coil, LOL.
    The amp is claimed to produce 400wrmsx2@2ohms, so 800wrms into four ohms bridged. Significantly overpowering your sub. Be careful with the gain control and volume and it will be fine. Max out the gain and/or volume and the smoke will come out.
    Sep 2005
    lol non of u beleive me bout tha 2 terminals, ill get a pic if i can, there called dual lug terminals, there next to each other, not on tha opposite side of tha sub.
    and as for overpowering tha sub by running it at 800rms at 4ohms, i was looking for a higher power audiobahn 12" (within a reasonable price) though tha audiobahn dealer at autosalon told me tha best match was tha AW122N, so thats wat ive got.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    we believe that the subs have 2 terminals, i just cant understand why there would be 2 terminals for one voice coil. Only thing I could think of would be for a sub with a huge power handling, like a DD9900 series, so you can hook 2 amps up to it. Posting a pic would be good
    VTII Acclaim
    Jul 2005
    NSW
    I believe you. I looked at it on the web. When i checked the sub and amp specs for those you posted.
    Just seemed a bit strange at first. Marketing? More is better?
    Anyway, as long as you like it, nothing else matters. Just be careful not to let the smoke out.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Yeh. So just connect to one of the positives and one of the negatives. Shouldnt matter which one
    Sep 2005
    thanks for that help guys.
    also just wondering if i've got the gain and that turned right down on the amp, can i have the bass boost switch on? or leave it off? cheers
  15. #15
    VTII Acclaim
    Jul 2005
    NSW
    On or off, whatever sounds best to you. Just adjust the gain properly with it the way you want. i.e. If you set the gain with bass boost off then turn it on without readjusting the gain, you may cause the amp to clip at a lower volume. This is not good for your sub.
    Personally, I prefer to use the hu eq to adjust this type of thing, not the amp. Fixed frequency boost is only helpful if the frequency it boosts is where you want it.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
  16. #16
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Bass boost is better for when you're listening at lower volumes, and want the sound to be more 'full' and bassy at low volumes
  1. vx wiring
    By funkman mixatron in forum Car Audio
    Last Post: 27-08-2007, 01:56 AM
  2. VR BCM wiring
    By alpine_exdemo_vr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 08:59 PM
  3. VH wiring
    By Jimboss in forum Car Audio
    Last Post: 22-01-2006, 12:38 AM
  4. Converting standard fog light wiring to driving light wiring
    By tungsten_vx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2005, 06:30 PM
  5. vt cd wiring
    By oldmate007 in forum Car Audio
    Last Post: 04-01-2005, 11:11 PM
