Results 1 to 4 of 4
Thread: amp upgrade
    vp calais
    May 2006
    adelaide
    Default amp upgrade
    if i end up upgrading my amp what should i et to drive 2 12" kewood KFC-W3010 subs? i dnt want to spend copius amounts on an amp but i want something that will make them thump?
    any sujestions?
    the spec of the subs are here http://www.kenwoodaudio.com/Australi...odel=KFC-W3010
    VY SS
    Aug 2004
    SE Victoria
    anything from jaycar's bigger sized amps will be able to run them or a pioneer from JB or something of the sort. you will probably get a good deal from jb if you dont want to import. if you want to import then i can tell you a few sites and tips.
    G4orce's Avatar
    G4orce is offline HSV Owner
    Vy Senator Signature 5.7lt auto
    Aug 2004
    Melbourne SE Subs
    For your subs I would just go a 400 or 500 watt Mono block amp. Make sure the amp is rated at 400 or 500 watt RMS or else it will not do as expected. I looked at your spec for the subs and they are only rated at 200RMS each so 500 may even be too much for your subs. I would recomend going to a JB HiFi and asking them for a mono channel amp that puts our 400 - 500 watt rms and they will do you a good deal. I would posibly go Cadence, pioneer or if you are willing to spend a little more go Kicker.
    Hope that helps.
    Good Luck
    My Beast VY Senator Signature 5.7lt Auto
    More info Click on like below
    lieos is offline what ford i didnt see it
    Aug 2005
    sydney
    go for the 1800w kenwood mono it does 500wrms 4ohm and 900wrms 2ohm my m8 has this amp and it goes good and they are rrp $599 so u can obviously get it cheaper then that
  1. BCM upgrade
    By Rocky1 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-01-2007, 10:28 PM
  2. Cat Upgrade
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2006, 08:42 PM
  3. 202 upgrade
    By glassfork in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 29-06-2006, 06:01 PM
  4. VX SS KW Upgrade????
    By sscrazy in forum General
    Last Post: 23-06-2006, 07:01 PM
  5. Rb 30 upgrade
    By vk deano in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 15-08-2005, 11:20 PM
