Results 1 to 7 of 7
Thread: Tuning ported enclosures
    DavidPartay's Avatar
    DavidPartay is offline somewhat awesome
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    Default Tuning ported enclosures
    Just a simple question, does lengthening the port(s) lower the dominant frequency of the enclosure? I got a ported enclosure from Jaycar a while back for my 10" sub and I've got the two ports sitting at the shortest length. It sounds alright and I probably have no need to fiddle but I think it might be worth having a look to see if I can tune it to make it sound *perfect*.
    Any tips?
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    Ported enclosures should be tuned with enclosure design software before construction, but since you already have the enclosure built, you can lengthen the port to lower the tuning frequency.
    Download WinISD Pro and put the sub and box specs in then adjust the port lengthm box volume, etc to see what the changes make to the boxes frequency response.
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    I ended up making the ports their maximum lengths (which is the same obviously) and it's slightly lowered the tuning frequency. Has made my sub a tiny bit punchier, along with setting the head unit to send it 'reverse' signals instead of 'normal' ? I'm guessing this is something to do with how the is mounted, like for band-pass enclosures and stuff? It sounds better even though the sub is facing outwards as would be normally expected!
    V6BEAST Guest
    u asked if the length of the port has an effect on the overall sound, well I
    b-leve that it dose, this is the easyst way I can discribe it, grab a straw from a thick shake and a straw from a std milk shake flatten the ends of each one and cut a point at the very end of each one, cutting towards the centre. now blow thrun the straw with the point in ur mouth u should get a buzzing sound the thick shake has a lower tone b-cause its diameter is larger than the std milk shake one. now dose length matter... while creating the buzzing sound chop off an inch at a time moving from futher away from ur mouth up to ur lips the tone will increase in pitch. i hope u still needed help and i did that...?
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    I didn't ask if it affects the overall sound, I asked if it LOWERS the dominant frequency . But thanks for your help, it's all sorted now, and I used to do that thing with straws when I was in kindergarten
    V6BEAST Guest
    no probs, but I have found that even simple things r confusing for simple people so i x plain them in such a way from the start
    02 VX Exec wagon
    Feb 2004
    Central Coast, NSW
    I hear you! Haha yeah I fix computers for a living... It's amazing how the existance of a computer can completely rob a perfectly good human being of any common sense or intelligence.
  1. eoi - v6 pod filter enclosures
    By stocky in forum V6 Development And Modification
    Last Post: 27-11-2007, 07:00 PM
  2. sub enclosures
    By vnbelina in forum Car Audio
    Last Post: 04-09-2005, 07:53 PM
  3. Sub Enclosures
    By lairdy in forum Car Audio
    Last Post: 28-03-2004, 02:05 AM
