Results 1 to 7 of 7
Thread: help me plz wiring question
    blaze's Avatar
    blaze is offline ridin dirty
    SILVER BULLET
    Jul 2006
    bunbury
    Default help me plz wiring question
    ay almost finished wiring me new head unit. just wondering were is the best place to wire Yellow(battery) lead says u have to connect it to the (+) post of the vehicles battery, where is this at? and also tha red wire it says to connect it to an open wire on the vehicle fuse box oranother unused power source that gives of 12V when the ignition is turned on
    HSV VP Senator
    May 2006
    3rd planet from the Sun...
    Quote Originally Posted by kritical
    What sort of head unit?
    If its in your VS then you will have a orange/white stripe for constant power connect this wire to your yellow wire on your headunit...
    As for your red or ACC wire that needs to be joined to a single yellow wire which is all in the same wiring loom as the factory head unit.
    Hope this helps......cheers
    Lets work as a TEAM and do it MY WAY!!
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    blaze's Avatar
    SILVER BULLET
    Jul 2006
    bunbury
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    actually, shouldnt the red wire on the hed unit be 12V constant and the yellow one is accessories? So you connect red wire on HU to orange/white on car and then yellow on HU to the yellow wire on the car?
    HSV VP Senator
    May 2006
    Quote Originally Posted by semi
    You can try that...and it will still work.......
    However everytime you turn the key off you will have to reset the headunit...ie clock, radio presets etc.....
    cheers
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    hmm, you're right. I was sure it was the other way round, but i checked and you're right. My bad
  1. amp wiring question
    By fredothefrog in forum Car Audio
    Last Post: 20-01-2008, 12:21 AM
  2. Sub/Amp Wiring Question...
    By stockvr in forum Car Audio
    Last Post: 12-04-2007, 01:01 AM
  3. Capacitor Wiring Question.
    By Wagon_Wheel in forum Car Audio
    Last Post: 04-12-2006, 01:57 AM
  4. VZ Ute - Stereo Wiring Question
    By robert_buntine in forum Car Audio
    Last Post: 21-11-2006, 10:37 PM
  5. wiring question
    By SweetWagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2006, 04:03 PM
