Results 1 to 10 of 10
Thread: Overheating Jaycar response amp
    VR Berlina auto s2
    Aug 2005
    the shire!
    Default Overheating Jaycar response amp
    g'day
    i recently moved my amp, (from behind the sub box to infront) and after about 30 minutes for driving around with the music on average volume it has heated up alot. Almost to the point of too hot to touch.
    the thing is i dont know if it was doing it all along or if it has just started.
    the amp is Jaycar response 4x50w. and it is mounted flat on mdf.
    any help would be great..
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    speaker wires shorting somewhere? power wire loose? was it mounted flat on mdf before you moved it?
    VR Berlina auto s2
    Aug 2005
    the shire!
    speaker wires are fine, same with power. it plays music fine, just gets really hot.
    It used to be mounted on its side
    VR Berlina auto s2
    Aug 2005
    the shire!
    VH commodore SL wagon 253
    May 2006
    the shire sydney
    is the amp designed so that its heat fins dissapate heat better while its on its side? and is it under your seat? its gonna want some air flow to get rid of all the hot air they are workin pretty hard alot of the time... mines under the seat but almost subconciously i chuck on the cold fan on feet and aim it between my legs to get some airflow. it hasnt overheated yet but i just dont wanna wreck an expensive piece of kit
    Achin' for a v8 wagon people click me!
    VR Berlina auto s2
    Aug 2005
    the shire!
    yeh thanks
    I've noticed when the volume is really low i can hear a distorted noise, likeall the guitars are dissorted. so im thenking that it might be the leads like hakhawk said, might chuck another set in and see how it goes.
    VR Berlina auto s2
    Aug 2005
    the shire!
    VTII Acclaim
    Jul 2005
    NSW
    My 4x100, driving front splits and a sub, gets too hot to keep your hand on it for very long after cranking for a while. Always has, still going strong after more than a year. I don't worry about it anymore.
    Class ab amps are not very efficient. A lot of the power that the amp draws does not go to the speakers and must be dissipated as heat.
    The jaycar amps have pretty effective protection. It should shut down if it gets too hot. It also has short circuit (over current) protection etc. The only time mine has ever shut down is when the battery voltage is low. i.e. power=voltsxamps, therefore for a given power out, lower voltage=higher current and therefore more heat.
    As far as distortion at low volume goes, well the jaycar amps are not great dynamically especially at low power settings. As long as it sounds good when up a bit, i wouldn't worry.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    Dynamat Extreme/Dynaxorb
    VT Acclaim Commodore
    Apr 2006
    gold coast
    hey mate i have a response 2x150 amp and i just had it mounted upside down under my parcel shelf, but the board it was screwed to was vibrating and i noticed it was getting way to hot up there cause the heat was coming out and going straight back in, so i moved it on the back of the box and its so much better doesnt get as hot and pumps hrder to now and thats on its side.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    did you run your power lines down the opposite side of the car???
    check ground points
    you could be getting cross talk especially if the power lines are the same side as the RCA (electromagnetic interfearance caused by current traveling through the wires)
    i have a black series 2x150W rms i had it mounted upside down and it heated up a fair bit despite the heat pipes i had in place to disapate heat into to the parcel shelf, i suppose its all about positing of the amp ....check that too much current isnt being put through small wires (is the gauge of your power wires enough, atleast 8 gauge)
    not using the right gauge wire can cause it to heat up and blow like a fuse excpet i think it would blow at like 400A not like 20A
  1. vx acceleration response?
    By daz08 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-04-2007, 06:40 PM
  2. Jaycar Response 1500w Mono Blocks NEW
    By buzurk in forum Parts And Other Items For Sale
    Last Post: 29-03-2007, 11:11 AM
  3. Replies: 22
    Last Post: 13-06-2006, 09:23 AM
  4. Fs New Response 4x100rms amp
    By H00LiGaN in forum Parts And Other Items For Sale
    Last Post: 30-03-2006, 05:16 PM
  5. response amp problems
    By matrix in forum Car Audio
    Last Post: 08-10-2005, 06:24 AM
