Results 1 to 6 of 6
Thread: VZ rear shelf wiring
    mrsnrub Guest
    Smile VZ rear shelf wiring
    Hi
    I have a VZ and am planning on putting speakers in the rear shelf. There is a 26 pin yellow socket under the shelf and was wondering if anybody can tell me what its for and if it carries speaker signals. It also looks like some of the wires from this connector end up in a 6 pin connector in the rear left quarter but I'm not sure.
    I have attached a couple of pictures if that helps.
    Thanks
    Attached Thumbnails Attached Thumbnails VZ rear shelf wiring-parcel_shelf.jpg   VZ rear shelf wiring-rear_quarter.jpg
    VY Executive
    Jul 2006
    VY SS
    Aug 2004
    SE Victoria
    the big multi pin one is probably stacker interface. use a dmm on the other one.
    mrsnrub Guest
    Unhappy
    Nope, never did find out what it's for and haven't had time to pull the back seat/shelf out again.
    Looks like rear speakers will be something I get around to one day!
    HSV VZ GTO
    May 2006
    Gold Coast
    The one under the shelf I believe will be the loom to go to the subs which is fitted in some models.
    The passenger side areas you are describing is where the sub amp is hooked up.
    I have a GTO and these are all attached as described above.
    Hope this helps
    Phreddy's Avatar
    Phreddy is offline Bye SV6 - still love you
    VS-II Statey-8
    Apr 2005
    W-Sydney NSW
    Hmmmmm - I had the parcel shelf trim out of a VZ Acclaim to install some 6x9s one time.
    From memory, the Acclaim had a component of the ESP sensor system up there. (Acclaim has ESP instead of the standard traction control like my SV6) That might account for the one on the parcel shelf...
    Cheerz.
    New look ASR Website online now!!
    www.asr-audio.com.au
    Interior lighting and audio specialties
    for VT/VX & VY/VZ Commodore / Monaro
    NOW VE DASH LIGHTING CONVERSIONS!!
    PLUS TECH2 DIAGNOSTIC SERVICES
    JBL Car Audio dealer
  1. Replacements for VS rear shelf
    By Scooter79 in forum Car Audio
    Last Post: 06-11-2007, 01:26 PM
  2. Rear Shelf Loose
    By Ronaldw in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-10-2006, 11:03 AM
  3. VT rear shelf
    By andrewgrazier in forum Car Audio
    Last Post: 09-06-2006, 10:58 AM
  4. VX rear speakers in parcel shelf
    By vyaw2003 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2006, 03:59 PM
  5. vp parcel shelf rear seat
    By smack006 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2004, 02:26 PM
