Results 1 to 10 of 10
Thread: Power Cable Through Firewall of VY
    Exceler8r's Avatar
    Exceler8r is offline (Ex-sell-er-rator)
    MY10 VE SS-V SE
    Nov 2005
    Melbourne, SE Suburbs
    Default Power Cable Through Firewall of VY
    Can anyone please tell me the best way to put a power cable for my amp through the firewall of a VY, it's not like my VT where just poke it through with the rest of the wires, the VY is far more quailty made and has a BIG rubber stopper and loom with all the wires going through. I'd prefer not to poke a hole through the rubber but if it's the only way then so be it.
    By the way, is it ok to run the RCA cables and the Remote Wire together?
    HELP ASAP PLEASE.
    Cheers.
    Long live the King of the Mountain - Peter "Brocky" Brock
    My Ride: 2010 VE SS-V Special Edition
    VTII Acclaim
    Jul 2005
    NSW
    My vt certainly has a grommet for the loom. The best place is down under the brake booster, there is a rubber plug with no hole in it that blocks the hole used for the clutch stuff in a manual. Remove it and make a hole in it, put it back and run the cable through it.
    Rca's can go with remote and speaker wires down the left sill, power on the right.
    JVC
    Focal
    JL Audio
    VDO Dayton
    Jaycar
    Dynamat Extreme/Dynaxorb
    chrgdstatesman Guest
    yeah i heard it is not good to put the remote wires together u get like different types of sounds coming threw, i red it somewhere **** remember where tho
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    ive recently came cross a vacant grommet in the firewall.. hard to see as its only bout 15mm diam and hidden in a blind spot. how to find it.. jus say u lookin neer the loom that runs thru the big gromet on the passenger side look about 15-20cms below it look more closer to the corner behind the wheel arch hard in the corner and you will come across it. from inside the vehicle when you remove the glovebox and side panels you have very accessable area to work with.
    hope thats of some use to you.
    cheers!
    VZ Monaro CV8
    Jul 2005
    w-sydney
    Quote Originally Posted by cold_carve
    cheers!
    yea thats the grommet i used, took me f**king ages to find it and at happly fits my 4ga wire through
    - b a r b s -
    Check out my Monaro
    VY SS
    Aug 2004
    SE Victoria
    i loike clutch gromets!
    clutch gromet in the easiest, no removing of glovebox and side panels.
    you need to keep the power and rca wires seperate. the remote wire does not matter. run it where ever.
    VE2 SS 6sp Manual
    Mar 2006
    Sth East Vic
    easy with running power cable... i had it run from me gromet down under the passenger side kickpanel and sill panels alongside with the left speaker cable straight to the amp... rca cable running along inside the centre console...
    end of the day it all depends on what amount of work u want to undertake
    have fun... cheers
    VZ Monaro CV8
    Jul 2005
    w-sydney
    have fun... cheers
    how about this: along the passenger side i have a 4ga power cable remote and 2 sets of RCAs (i bought some nice insulted ones and i dont here that crap you would otherwise, cost me a few quid though) i was only trying to run the speaker wire down that same sill but its a little packed in there.
    you see its not because im lazy (but i am) its just the less i touch the less ill break and the less it will look bad.
    - b a r b s -
    Check out my Monaro
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by barbs
    the noise floor of the RCAs' will be raised regardless of if you can or cant hear it. it is a bad idea plain and simple. its the same as running a crap cd player, it all has the effect of making the system sound worse.
    Exceler8r's Avatar
    MY10 VE SS-V SE
    Nov 2005
    Thanks for all the help guys, I actually found the hole you were talkin about before i had the chance to check back here for updates, so yeah. I appreciate the help.
  1. amp power cable, No hole in firewall. :(
    By phat_com in forum Car Audio
    Last Post: 02-04-2007, 11:45 AM
  2. Running power cable in firewall "VP"
    By wrx884 in forum Car Audio
    Last Post: 07-01-2007, 11:16 AM
  3. Replies: 9
    Last Post: 22-07-2005, 09:40 AM
  4. Clutch cable grommet in firewall
    By Dexn in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2005, 11:05 AM
  5. Vn Firewall And Amp Power Lead
    By nielo in forum Car Audio
    Last Post: 07-05-2004, 09:13 AM
