Results 1 to 2 of 2
Thread: new sub, old amp
    VT Executive
    Aug 2006
    Default new sub, old amp
    hey there i got a new sub from strathfield details as follows:
    Peak Power: 1300W
    Rated Power: 380W
    Frequency Response: 18Hz - 2kHz
    Impedence: 4 ohm
    Sensitivity: 89dB/W/m
    http://www.strathfield.com.au/ViewPr...sp?ProdID=1778
    i have a old 2chanel 120W amp hooked up to it (bridged) but it sounds like s*** just woundering wot would be the best amp suited for this sub, and if any1 else has the same.
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    An amp that makes 380Wrms at 4 ohm. Easiest way to get that power would be a 2 channel rated at 100-150Wrms per channel at 4 ohm. If you want a cheap amp that'll "do the job" the Jaycar 2 x 150W would be great for it.
    So what's the problem? It sounds like a normal Sony sub?
