hi i have a us audio sub it is a 10"
i am stuck on what kind of amp to use?
a mono one is the right one but wat size? the sub
is no more then 400w
then if i was to buy a amp for it would i be able to run 3 subs off the mono channel amp?
you have got to love it when people look but dont reply..![]()
you would be better off buying a 2 channel amp to start with if your planning on running two other subs later on, then al you need to do is buy the same 2 channel amp and run the other 2 subs off that and have a spare channel cos running 3 subs off a monoblock amp wont be as affective
JBL 600.1, value for money unbeatable (around $400)....same product from alpine around $1100, just my 2 cents![]()
SUPERCHARGED V6 VS CALAIS
R.I.P Peter Brock 05 The Man The Legend
thx guys...
ill look in to it..
thx for ur help. any other suggestions would me greatly appreciated
yeah i looked i just couldn't be bothered explaining about impedances and all that then.
why do you want 3 subs?
do a search for impedance on the net and then you will understand how different subs can be wired to maximise an amp's potentional power.
but its still comes down to WHY 3 subs?
save yourself a couple of bucks on subs and go for just 2 and put what you've saved towards getting a better amplifier.
Also, in no way will a mono be more efficient than 2 2 channel amps. The only time it might be is if you want to run one 4ohm sub
can you please explain?Originally Posted by semi
ummm. class d amps are more efficient than class A/B. Am i missing something?
you said that 2 2 channel (A/B) will be more efficent than a class D.
oh. I meant that if you're running a 4ohm sub, you can get more power to it sometimes by running a 2ch bridged at 4ohm than you'll get from a cheap mono that makes best power at 2. Not technically more efficient, but you get what i mean
ah yes with you now, sorry i take everything as its written!Originally Posted by semi
