Results 1 to 22 of 22
Thread: 1 or 2 subs
    VS CALAIS's Avatar
    VS CALAIS is offline S/C CALAIS
    VS S/C Calais
    Jun 2005
    MELBOURNE
    Default 1 or 2 subs
    Hi all.
    Just a question regarding subs. would 2 subs say rated at 300wrms each sound better than 1 sub rated at 600wrms ? just after nice deep n low bass but not sure what to go with 1 sub or 2 subs
    Oh either set up will be run from a mono block 600wrms @ 2 ohms
    Thanks in advance
    SUPERCHARGED V6 VS CALAIS
    R.I.P Peter Brock 05 The Man The Legend
    VY SS
    Aug 2004
    SE Victoria
    would an eb falcon sound better and a vp?
    i dunno.
    do you mean be louder or better SQ? you would "probably" have better SQ from a single sub because of it costing twice as much as the 2 others.
    personally i would go for a single sub in a ported box because you want the lower end excursed more, and a sealed box will not provided that as well.
    VS Acclaim S2
    Nov 2005
    It's a very subjective question this one and one that gets argued constantly. Say your willing to spend 'x' amount of dollars on either one good sub or perhaps two not so good subs then that cost is fixed. After that a few basic things to consider are how much room you want it to take up, how much more/less money and hassle it will be to have two subs instead of one (might not be much hassle at all) and whether you want 2 subs so it looks pretty but doesn't sound prett or a nigel sub that sounds pretty but doesn't look pretty (not to say that two won't sound just as good - as i said, very subjective).
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    i dont think its something argued about between people that know their shit at all. Its basically said that you'll get better sound from a single, more expensive sub than 2 more expensive ones. Assuming everything else is the same, the 2 subs will have twice the surface area and therefore twice the volume (an extra 3db) which isnt really worth it. Then the more expensive sub might have more excursion, etc etc
    Agree with garfa on the sealed box for better low end excursion, try and get a sub well suited for ported boxes though
    VS Acclaim S2
    Nov 2005
    Quote Originally Posted by semi
    Well i still seem to see it discussed between people that 'know their shit', but hey that's just me, opinion each to their own.
    troyjm310's Avatar
    troyjm310 is offline Yortabulous
    VX Berlina series 2
    Oct 2004
    Wesside Sydney
    try a nice DUAL Voice coil sub
    no need for 2 unless your really silly or like the look of 2 subs ?
    depending on set up if its going to be a show car or general usage ?
    VS CALAIS's Avatar
    VS S/C Calais
    Jun 2005
    MELBOURNE
    Quote Originally Posted by troyjm310
    any suggestions / recommendations ? what would be better
    Alpine type r 12"
    mtx 7500 series 12"
    kicker comp vr 12"
    any others in that price range ??
    any help would be great
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Why a DVC sub? It doesnt make them sound any better
    VP Exec
    May 2006
    Quote Originally Posted by VS CALAIS
    Alpine type r 12"
    mtx 7500 series 12"
    kicker comp vr 12"
    i like the sound of the alpine personally, the type r are quite powerfull and give quite a clear sound, but i also havent taken that much notice of how the other 2 that u r thinking about sound
    1 type r would be just as powerfull as my 2 clarion subs (375w each) and give much better quality, but that also depends on how much u want 2 spend, i didnt have a big budget so i got cheaper subs (hence clarion, not usually a clarion fan) i also went 4 the 2 subs for looks aswell, most of my problem with sound quality is having 2 6x9's in the parcel shelf, turn them off and it sounds much clearer, but also a lot less powerfull so i keep them on, when i get an amp 4 them though i will setup a crossover so they arent playing so much bass
    troyjm310's Avatar
    VX Berlina series 2
    Oct 2004
    Wesside Sydney
    Post deleted due to copyright
    VY SS
    Aug 2004
    SE Victoria
    you need to say what source you got that from otherwise JC can get into shit.
    just because its dvc means squat. sometimes its a disadvantage, because you how the 4 ohm coils are never 4 ohm load at the amp. each system must be thought out and if a dvc is needed then go for it but its as much an advantage as disadvantage.
    Troy711's Avatar
    Troy711 is offline Moderator Puppeh
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    if this is copyrighted material, or taken from another website you MUST post a link to it or it will be taken down.
    VS Acclaim S2
    Nov 2005
    Alpine type r 12"
    mtx 7500 series 12"
    kicker comp vr 12"
    I picked up a nice oldschool Soundstream Rubicon SVC sub off ebay for under $30 that came in a good old prefab box, bargain! . Nah, it'll be moving out of home when i get around to installing my new setup.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Thanks for the lesson in basic electronics, although yuou failed to mention why a DVC sub is better, except in specific circumstances
  15. #15
    Troy711's Avatar
    2007 WM Statesman
    Dec 2003
    Canberra, ACT
    Blog Entries
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    well in my own experiance 2x subs over 1x sub pushes more air and gives you more feel with the volume where 1 will give you the volume not the feel of everything shaking around you... personally i prefer 2x woofers
    just my 2c and
  17. #17
    VY SS
    Aug 2004
    SE Victoria
    Quote Originally Posted by PaRaDoX616
    just my 2c and
    yes about 3db more of imaging (feel). i think theres a bit of the placebo effect happening.
  18. #18
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
  19. #19
    VP Exec
    May 2006
    im not sure if this is right but ive been told that dvc subs give slightly sharper/clearer sound, i wasnt bothered by this coz u doubt u could really tell the difference in my car
  20. #20
    VE Calais-V 6.0L
    Aug 2005
    Hastings
    DVC subs sound no different to a single voice coil sub. They have dual voice coils so you can wire them differently, that is all.
  21. #21
    VY SS
    Aug 2004
    SE Victoria
    nah man mi alpine subbie is way louder than my m8s and itz dvc! just shut up u fool!
    oh god please dont smite me!
  22. #22
    VS Executive, VY Executive and VE SS-V
    Jul 2006
    Alpine type r 12"
    mtx 7500 series 12"
    kicker comp vr 12"
    I would go MTX 7500 Series 12" but then again MTX is the brand I like and is good quallity and sounds awesome as.
    But I have a MTX T9500 Series Dual Voice Coil 4 Ohm 15" sub and its ****in sweet as.
  1. FS: 2x 12" Pioneer VCCS Subs in Custom Box! Silver Cone Subs!
    By 1991_Vn2nV in forum Parts And Other Items For Sale
    Last Post: 06-01-2008, 08:27 PM
  2. subs in ute
    By aussieboy in forum Car Audio
    Last Post: 27-02-2006, 06:19 PM
  3. JL subs
    By VX_GIANTZ in forum Car Audio
    Last Post: 11-01-2006, 10:18 PM
  4. where to put subs in vr ute
    By speedy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-08-2005, 08:58 PM
  5. Vs subs
    By Stretchomatic in forum Car Audio
    Last Post: 07-05-2005, 09:43 PM
